Let's see everyones engine pics...
240sxHitman
Car: Boosted '91 240sx
thats is freakin amazing, i want that setup. my mouth dropped after seeing that. excellent work. i was gonna do kat but i think imma lean over to the RB's
27RB240
Car: 92 240sx coupe
240sxHitman wrote:thats is freakin amazing, i want that setup. my mouth dropped after seeing that. excellent work.
Imissmyturbo
Car: Car's, Turbo's, sking
aznromeox What kinda power did that RB25 S13 put down?
95silvia
MAN .... that is the 2 cleanest installs I ever seen.... and I was afraid I wouldn't be able to find and cool rb guys to hang out with when I move home to Renton in 10 months. Where you @? i saw you where in (253) anyway it goes unsaid be still good to hear... bad *** work and great job on the cars and the motors. Cjex
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
GAH! Those bays are breathtaking!
-Dan
CursedGTR
Car: 1991 Skyline GTR
Been working on this for quite a while but have come up short on thigs to do in In the past couple of weeks, so I have replaced every bolt I could with stainless HEX bolts, I even found some to replace the studs on the water pump pulley (kind of an OCD thing).
Replaced the front oil return with a -12 fitting (it is a 3/4NPT thread for those of you who might want to know), I intend to Y my oil returns and run them both into this fitting.
I disassembled and painted my Alternator (again the OCD thing, I just couldn't stand it not matching and it drove me nuts)
The valve covers and throttles got finished up at the paint shop (Thomas Caudle here on Okinawa, he did the pain exactly as I requested and it was very reasonably priced). It is a silver base with candy blue flames. Although you cannot see it unless you look at it in the right angle there is a purple hue blended into the flames that you cannot see unless you are at the exact angle needed. very cool paint job in my opinion
Put the turbine kit and intake manifold on
Plugged off the Heater Core Outlet on the rear of the block (Again 3/4 NPT)
I will have to thread the one for the port on the thermostat housing (It will be about 1/2NPT)
For the most part I just puttered around looking for **** to do. The pics should speak for the results. Needless to say, I am pretty Happy with it.
I will get the manifolds coated when I get back from Iraq, I will also do the wastegates (cast iron parts) and the turbine housings, and in my obsessive compulsive tyraid I will probably waste my time and polish the aluminum part of the waste gates.
I have been posting on this forum in the past so figured I would post the finished product in here. The motor is fully built from the bottom up so it will do more than just look pretty as well.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
^ Hot!
bigbadbrad
, The black and silver RB is..............wow
blk90s13
AmoebAssassin wrote:^ Hot!
yes it is
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I feel like my motor sucks now Those things are literally works of mechanical art!
IceSkyline25
Car: 240sx
Here's a pic of mine
Shocker
Car: 89 240sxHB rb26/30
interesting intake mani you have there, hows it working for you?
blues14
Car: 1995 Nissan 240SX GTS-t
Did you make that mani? Never seen one like it.here's my engine. Hopefully there will be a big metal snail in it next year
foCk
i like my dirty engine bay
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
nice! are you still running the ssac turbo?
T4 RB25det
Car: 1995 240
IceSkyline25 wrote:Here's a pic of mine
Rb20?
Eikon
Car: 71 240z, 93 Supra TT
T4 RB25det wrote:
Rb20?
I'm guessing by the "25" in his name, and the 2500 on the valley cover, and the bump on the intake cam side of the timing cover... That's an RB25.
krayton
but doesnt it have the straight valve covers with no hump, and the intake manifold with 5 and 6 closer?
or is it a NA rb25.
i guess rb20 outfitted in rb25 clothes
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
could be a rb25de head?
Eikon
Good eyes!
Those do look like 20 valve covers, and the lower intake runners look like they are from a 20.
but, search his previous posts. He says he has a 25..zerothread?id=173529
Oh boy.. You guys don't think he got scammed into paying rb25 $$$ for a Rb20 do you.. read this post..
IceSkyline25 wrote:I have an S13 with an RB25.. i just bought the car with the swap already done so i am having to fix problems here and there.. I got the car running but for some reason it feels very sluggish... i know for a fact an RB25 is supposed to pull harder then this.. I have checked for boost leaks and i didnt find ANY.. my BOV isnt leaking either.. The turbo has no shaft play in it whatsoever and it sounds like it is boosting.. My turbo bolts backed off before but now i have them on tight and they arent going anywhere.. It doesnt really sound like there is an exhaust leak.. Ive been trying to also figure out the vacuum diagram but i have a custom intake manifold so its hard getting some accurate diagrams.. also just changed the plugs.. plus i am running 40 PSi of fuel pressure.. i have a cheap **** FAZE boost gauge and it sputters when i hit full boost.. is that because its a peice of **** or because its some type of problem? let me know what you guys think what my problem may be.. i have an event on the 21st that i would love to rip at.. also you guys have any pics of PS on an S13 with an RB25?
OKRB20DET
Car: 1990 S13 coupe
he could try and stick a greddy intake manifold on there and that will answer the question 20 or 25
kjlindgr
Here's my sally of a motor swap:
krayton
oooooo, that looks like fun.
but rather then jam the greddy manifold on, just look at the block engine code. will tell u right away
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
what chasis is that KJ?
Eikon
Kansei240sx wrote:what chasis is that KJ?
oooh oooh I know.. Pick me!!!!
nah... I'll let him answer himself.
That's gonna be a slow car... That's why he's got the two hook on the front bumper.. He can hook up to my Rb20 and I'll pull him down the track.
On that RB25 vs. RB20 issue... Easier to pull the timing cover off and see if the intake cam has a lobe for um... "vtec"... he he.
sparksta
haha that car is going to be pimp. The only reason i know what chasis it is, is because i've been dead set on that swap for several months now. i'm happy to see that there might be some help out there when i get around to doing my install (prolly 2020 but who cares!). looks great man!
foCk
yes sir nearly 10.000mi on it by now
Carl H
2jz-gte no siht!looks like a supra to me...
kjlindgr
FD3S
Chaos the Xile
Car: 1974 Datsun 260Z
MY RB25 w/ GT35R WHOOOA!
