led help asap
mistic1209
Car: I have a 2007 infiniti m35 x first owner with 53000 miles And also A 2012 Range Rover sport
have a 2007 m35x want to convert all the interior light and door lights to bright led plus back up and daytime running lights too
Twizz
Car: 2007 M35X - Stillen exhaust, Injen CAI, dropped on Espelir springs, Morimoto 3K Hid Fogs, Morimoto 6K low beams, Full interior and exterior LEDs, air horn, 35% tint all around(45% on the windshield)
I have the same car. I converted all my lights inside and some outside. I got all mine from ijdmtoy.com
They have packages you can order for the car, but I wanted a different set up than the bulbs they were giving in the package. So I decided to use the sylvania bulb guide n pick the different types of bulbs off of that. Came out perfect.
merlinq2
Car: 2007 Infiniti M35x
Good to know, I have one question. How did you handle the map lights in the front of the car. I broke the housing and have to replace the entire fixture. A real PITA for sure
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
Good thread I think I'm going to go with the package deal Hey (Twizz) does that cover all the inside lights?
Logan00
Car: 2008 Black M35x
Has anyone gone with the blue interior lights? If so, how do they look, do you have night pictures with them on?
Thanks
Twizz
merlinq2 wrote:Good to know, I have one question. How did you handle the map lights in the front of the car. I broke the housing and have to replace the entire fixture. A real PITA for sure
Mine went in with no problem. They were pretty simple. The hardest part was contorting my body to get them in. Other than that, they were pretty simple.
Twizz
lovemycarM35 wrote:Good thread I think I'm going to go with the package deal Hey (Twizz) does that cover all the inside lights?
They have different ones. They cover the map doors n lights back lights inside. But they also have some that cover the lisence plate lights.
I got reverse parking trunk all inside and lisence plate lights done.
I posted some pics of my car a few months ago. I think its titled "my car 1 year later" or something like that. Check it out you'll see what the lights look like at night
merlinq2
Not sure I understand, I was talking about the lights that right by the sun glasses holder. The one above the front center console. That is what I am talking about. The pins that hold in the bulb broke and the I need to pull out the entire assembly to re wire and solder the contacts.
Thanks
Logan00
Twizz I found your pictures, are your interior lights blue? If so I like them and may go the same way.
Thanks
Twizz
Logan00 wrote:Has anyone gone with the blue interior lights? If so, how do they look, do you have night pictures with them on?
Thanks
The "hyper white" ones are actually kinda blue-ish tinted. The blue ones would be really blue. I wouldn't suggest those. They Kinda make the car look "ricey" IMHO. You will see when you look into it
Logan00
So you have the white ones? Your pictures make it look blue so that is why I thought that. I don't want it extreme blue so if that is what I will get from the blue bulbs I will stick with white.
I just looked at the pictures on the link and the blue is definitely not for me, I will go with the white.
Thanks again for the link.
Twizz
Logan00 wrote:So you have the white ones? Your pictures make it look blue so that is why I thought that. I don't want it extreme blue so if that is what I will get from the blue bulbs I will stick with white.
Not a problem. Hope they work out well for you ! :dblthumb:
Logan00
Me too :biggrin:
By the way, is there somewhere in the manual that says how to get to the map lights?
06M4.5
Car: 2006 M45
This has good info with lots of pics:
led-upgrade-project-dome-light-conversion-t397318.html
Twizz
Mine went in with no problem. They were pretty simple. The hardest part was contorting my body to get them in. Other than that, they were pretty simple.[/quote]
Thanks[/quote]
I didn't have that problem. I knew which ones you were speaking about, but I didn't have any issue. I just put them in and that was it. Don't remember if I had to turn them or not though.
