Not sure either, but I know early QX4's had a slightly different system that was a combo between the mode switch and manual shifter (i.e., it had both). They eventually went to a switch-only setup.yeldogt wrote: Hawairish: I may be wrong .. but I think the QX4 and the Pathfinder LE past 2002 have the same set up. Mine have all been 02 LE's -- so I'm only going by that configuration.
I'm not sure what I am going to do when this one has to go -- maybe I will get lucky and find another perfect one ... this is my third. I like that I have the locking center when I need it and have the "Auto" for the rest. I have a big property and the ground clearance and toughness of the Paths system is desirable over most of the AWD systems in all the crossovers.
