MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Sun Oct 26, 2014 9:00 pm
Interesting. I've actually found multimonitor support to be better with Mint. Under Kubuntu a lot of Wine programs would lose mouse sync if the OS saw the mouse leave the main monitor but the program did not. Diablo III was unplayable because of this, so I'd have to disable my 2nd monitor to play it.
I also like that Mint leaves secondary monitors "on" (showing the desktop rather than blacked out) even when running fullscreen programs on the main monitor, unlike Kubuntu.
But yeah...Being an ATI owner, I can understand how drivers can make or break things. xorg drivers for my AMD card (6870) are actually pretty stable and functional these days, but a couple years ago they were basically unusable, and AMD's own flgrx drivers were only marginally more stable.
As for GUI, I am fine either way, but if I'm going to have a GUI it needs to be well-designed. I'd rather have no GUI than a crummy one (Unity, Gnome3, Windows Modern). But for everyday computing, most the programs I use are designed for GUI use, so having a GUI desktop environment just makes sense.
Much of my early computer experience came from Apple IIs, DOS PCs, and Windows 3.1, so I'm very comfortable in a command-line, but I also appreciate the ability to utilize my monitor space efficiently with a modern desktop setting. Even in the Windows 95 and 98 days, I still made fairly frequent use of the "DOS prompt". XP and later versions of Windows moving away from command line more completely never really suited me. Even in Windows 8, I have PowerShell set as default over CMD because I use it frequently enough to appreciate its benefits (and you can't do certain things in the classic cmd prompt anymore). That's also why I get picky and always make Terminator my very first application install on any clean Linux install.
OS X's black-on-white terminal color scheme drives me nuts, while we're talking terminal. It just doesn't feel right. Makes it feel like a text editor rather than a terminal emulator.
