Brody77 wrote:Yikes!! Yeah, I don't need a hole in my piston (that is what I'm looking at, correct?). Given the steps I've taken thus far, what I've deduced is it can only be either a vaccum leak on bank 2 or a exhaust leak before the bank 2 upstream O2 sensor. I don't think it's an exhaust leak because that should be fairly easy to notice (i.e. see, hear, & smell) and I've been all around that side of the engine for days and can't see any signs of an exhaust leak. Some people have mentioned things like a faulty EGR / PCV valve or even a malfunctioning bank 2 sensor but all those things have their own trouble codes when they malfunction and I see why I wouldn't be getting O2/EGR/PCV specific codes if indeed one of those items were malfunctioning.
My wife thinks I make problems with my cars because I am always "fiddling" with them. I'm starting to think maybe she's onto something. It does seem like people who don't care about their cars and just get in them and drive them don't have the problems I do. When I met my wife she drove a 1990 Honda Accord that she literally never did a single maintenence item on for the 5 years she owned it - never washed it, never changed the oil, nothing - and she never had a mechanical problem with it. And as I mentioned before, my dad bought a 1996 Q45 almost new and he wasn't much better. He drove it on miles of dirt roads everyday (lived in the country), only put 87 octane fuel in it, and maybe changed the oil every 10k miles or so at best with whatever the cheapest crap oil/filter the quickie oil change place happened to have on special that day and maybe changed the air filter once or twice. Never changed the transmission fluid. Never flushed the radiator. Never serviced the differential. Never even changed the spark plugs. Just got in and drove it. Drove it for 10 years and put over 250,000 miles on it without a single major repair. He's driving a 99 Toyota Avalon now that has 195,000 miles on it and is still on the original timing belt.
Maybe he's just lucky, I don' know. All I know is I have a 99 Q45 with a fraction of those miles on it and thus far I spent twice as much time under the hood than I have behind the wheel
I had similar problems for the first 5-8 years I worked on vehicles. I then discovered the beauty and importance of the torque wrench. Just because it is "similar" in resistance to turn two bolts does not mean they are even close in torque...rust and sand can work wonders on the difficulty to turn a small bolt.
IN ALL AUTO PROJECTS, BE SURE TO:
-Always clean nuts and bolts.
-Lubricate if AT ALL necessary to remove tough bolts. If a bolt is hard to turn, you will do more damage horsing it out than lubing it quickly.
-Clean receiving threads whenever possible.
-Wire brush nasty stuff from ALL threads.
-MOST OVERLOOKED - replace bolts if necessary. My point is that it is OFTEN necessary and people don't even realize it.
-ALWAYS use PB blaster or equal on tough bolts so you don't reshape them and affect their effectiveness when re-torqued.
Remember, manufacturer's don't go through the tons of trouble to engineer torque values on nearly every bolt on the car for no reason. Suspension torques with rubber bushings, brake torques with caliper slides, ALL engine torques connecting aluminum especially.....
"Shadetree" mechanics get everything "just right" until everything is "just wrong."
I should know - I'm one of them
