Latest drag strip vids....In-Car cam...
Booztd 3
Car: 1990 Nissan 300ZX TT
Car was running great the night before but as soon as I got to cordova it started breaking up in 2nd,3rd, and 4th gear in the higher boost range......im starting to wonder if the E85 winter mix found its way into the car...
11.1 @ 1251.5 60 foot
In-Car
http://www.youtube.com/watch?v=A6KPkPbra8c
Sideline
http://www.youtube.com/watch?v=ulIwOchPaBU
11.5 @ 1231.9 60 foot
The car was breaking up worse and worse
In-Car
http://www.youtube.com/watch?v=NRnvpeaRoa8
Grandstands
http://www.youtube.com/watch?v=WkAHkkiMDx4
Timeslips
Curious as to what that 11.5 pass would have been with a 1.5 60ft....
WhatsADSM
Car: 1998 240sx
That 1.5 60' is insane, I would kill for one of those. Especially for 17" ET Streets. Which suspension are you on again?
Congrats on the times BTW.
gawdzilla
Car: none
i love how this car gets off the line!
Booztd 3
WhatsADSM wrote:That 1.5 60' is insane, I would kill for one of those. Especially for 17" ET Streets. Which suspension are you on again?
The suspension (with the exception of solid subframe spacers) is BONE STOCk...and when I say stock.....i mean, its 20 year old stuff, lol
WhatsADSM
Car: 1998 240sx
Ahh stock suspension makes sense... It actually helps to be honest since you get all of the weight transfer. I actually have trouble getting any decent weight transfer even on full soft on my Tein coilovers.
You are right there, just a little more boost/timing and you will see 10s!
Booztd 3
WhatsADSM wrote:I actually have trouble getting any decent weight transfer even on full soft on my Tein coilovers.
that's exactly why I've never deviated from the stock stuff
RBcoupe
Car: 89 240sx, RB26
man thats sick, i would love to get a 1.5 60'.... best i have done is a 1.74 and that feels insane...
raremotive
Car: 04 Infiniti G35
Back to manual, I thought you put in a quick shifter a while ago?
Booztd 3
Rare_f8 wrote:Back to manual, I thought you put in a quick shifter a while ago?
It had a TH400, and i didnt like it...
raremotive
I don't blame you, I still like the fine control of clutching and shifting.
toadx8u
Car: 1975 Datsun 710(coming soon F20C)
1993 240sx Vert DD
1995 240sx GT3788 RB25DET
1996 240sx LSx 5.3L
2000 F-250 Crew Cab Diesel
2004 Honda RC51
you say your running et streets what size and psi are you running...cause it sounds like your spinning awefull hard through most of your gears...i run 12 psi in my bfg dr comp t/a's
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Great lookin ride man!!
What Exactly was wrong with the th400?
Also I think you can cut that 60ft down a little more and also not get that small bog you got going on by holding that 2 step a little longer.
Personally I Pre-stage and Bring it up on the 2 step and roll into the stage light by using my ebrake to stop myself and also pre-load the drivetran so its not a terrible shock. I think your car has alot more down low. I would say a clean pass all the way your lookin at a 10.8
Booztd 3
toadx8u wrote:you say your running et streets what size and psi are you running...cause it sounds like your spinning awefull hard through most of your gears...i run 12 psi in my bfg dr comp t/a's
I'm actually running ET Street Radials.......big difference between that and just ET Streets (they are bias ply)
The size is 275/45/17's
I dont spin in any gear except for the launch
Booztd 3
rb25drag wrote:Great lookin ride man!!
I really like driving the car around, its a street car. A th400 is 3spds, and 3rd gear is 1:1, which is identical to 4th gear in our Z32/RB trans......imagine trying to drive to the drag strip w/out 5 gear
Add to that.......the heat. When you have a pretty high stall converter, its going to be slipping ALOT. Slipping leads to heat, and that heat transfers right into the drivers compartment. On a 20-30 minute jaunt, I'd find myself sweating with the windows down
The unfortunate part about track days like the one I just attended is that its full of alot of novice drivers, who may not be familiar with the staging process, so rather than have my car sit on the 2-step for extended periods of time (for those of you who dont know, its not good on valves) I just wait until I see the yellows.......now if I was competitively racing, that would be a different story
I agree the car has alot more down low, but my whole goal is 10's in 'street' form.........to be perfectly honest, i didnt touch a THING in this car when i went to the track sunday, I didnt even touch the tire pressure. I literally unloaded my tools, went to tech, and pulled in the staging lanes.
dsrturbo.com
Car: nissan
not bad
Booztd 3
I actually have my 2-step set to disengage off the clutch switch, so I wouldnt really be able to hold the 2-step out more........for some reason my VSS wasnt sending signal to the ECU otherwise I'd be able to set the condition for the 2-step to be on for anything under 10mph or so....
rb25drag
HAHA I understand about the Novice driver part! There at every track. Luckily at my local I get alot of solo passes which help esp with staging.
Wat I was referring to when i said hold your 2 step longer was just bringing it up on it a little quicker than you was. From what I was hearing in the video Your turbo was not getting spooled enough before you hammered it. I think if it was held about 3-5 sec longer it would pull threw that small bog and Honestly I think you could see a 1.4 60ft.
If your racing against Drivers that take a long time to stage. The way to bring it up without having to hold it forever and wait on them is pre-stage and wait on them to fully stage, Bring it up on the 2 step and roll it into the stage and then there is no waiting.
What rpm do you have it set at?
ANVIL
Car: RB25DET S13.5
damn that thing is a beast coming off the line!!! ever broke any axles launching that thing? how much whp do you have?
Booztd 3
Its right around 6k right now.....
It looks like it was in full boost (25psi) on the launch, im not sure if you have the ability to see AEM logs, but here is the one on the 11.1 pass...
http://www.booztd3.com/Picture...3.stf
I have the 2-step enaged off of switch 3, which should be logged, so you can see when I dumped it
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Andy is that a line lock I see you fiddling with before and after your burnout?
Booztd 3
Darius wrote:Andy is that a line lock I see you fiddling with before and after your burnout?
indeed
Theres a switch to turn on the mirror defrosters, and since I wont ever use that, I wired the line-lock into that switch for a 'stealthy' look
Booztd 3
ANVIL wrote:damn that thing is a beast coming off the line!!! ever broke any axles launching that thing? how much whp do you have?
I broke an ouput shaft once, but I can attribute that to alot of wheelhop and having an OS giken triple plate
WHP was prob around 550
gawdzilla
Car: none
Booztd 3 wrote:The unfortunate part about track days like the one I just attended is that its full of alot of novice drivers, who may not be familiar with the staging process, so rather than have my car sit on the 2-step for extended periods of time (for those of you who dont know, its not good on valves) I just wait until I see the yellows.......now if I was competitively racing, that would be a different story
How do you know these guys who you view as novices arent intentionally burning you down at the line? J/K
you should probably just camp on the green and set up for a perfect launch. forget the RT to get a good ET.
the_garynator
Car: 2015 370z Sport
93 RB26 S13 Coupe
96 SBC Hardbody
Sweet!
So you're launching at 6k? Do you let off in first to get that traction back or are the tires just hooking up like that?
rb25drag
sorry cant read your log.
I also run my 2step off the clutch pedal. Its a nice tool for the track
I also have line lock!! OMG!! It saves your brakes so much HAHA, I love it too, Its also good for when someone is riding your *** and you come to a red light!! I have been known to sling **** all over someone before LOL
Booztd 3
the_garynator wrote:Sweet!
I never let off unless i detect some spin......then I pedal as needed
Booztd 3
gawdzilla wrote:How do you know these guys who you view as novices arent intentionally burning you down at the line? J/K
I never worry about R/T unless I'm actually in a competition, which hasnt been for a few years.....when I was running my last actual brackets, I was cutting .05-.06 on the pro-tree
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
very nice man im hoping to break into the mid 11's when i go to the track
Booztd 3
HxC_Nismo wrote:very nice man im hoping to break into the mid 11's when i go to the track
With almost 500rwhp and the weight of your car...........some slicks and you should have no reason to not go 10's.....
My **** weighs like 3700lbs and im making maybe 550-560rwhp
Cjmartz2k
Car: Hunting for a '89 GTR now
Man, you guys are making me miss the states bad. The best we can do here on Okinawa is a Gtec, but I'm not so sure how accurate it is. The roads here are so bad I spin all the way through 3rd on 275 nitto's I'd stab somebody in the face with a hot soldering iron to cut a 1.6 60', or even just limit my wild wheel spin to 1st gear.
Stock suspension is working that good for you, eh? Making me think about going to JY.
I really like your car man
