Apologies...I AM going to attach it to the block...I forget how "attention to detail" everyone. Is on the forum) I. Obviously on a technologically advanced and large motor like this there should be many machine thread screw holes on the block.. I just need to know where the best ones are, and what length and thread pitch bolt I need to use to get it on there. Also, does it make a difference how long the wires can be extended to get to the new mounting location????elwesso wrote:If you're going to relocate them and not have them mounted to the block, you might as well just add a resistor on the KS harness. I'm not thrilled about that idea because if someone puts regular gas in the car and it starts knocking the engine has no way of knowing if it's knocking or not. You can at least replace the KS without taking the plenum off, so I don't see why you don't just replace them. You could destroy the engine doing this if bad gas was used, costing you more in the long run, IMO.
Best location will be near a piston at TDC (since that's where knock occurs), and away from other noise-producing parts (valve train, belt-driven accessories, etc.). The intake side of the engine is preferred, since the exhaust side tends to cook sensors.Wiggler wrote:Obviously on a technologically advanced and large motor like this there should be many machine thread screw holes on the block.. I just need to know where the best ones are
I just love it when this dimented individual refuses to read the true intent and objective of the owner of the vehicle who happens to be debating on SELLING his vehicle. The same thing occured when I asked about how to remove a plastic footrest on the driver side footwell which was underneath the parking brake. He thought I was trying to remove the parking brake itself!! Gentlemen, Irrefutable proof that senile dementia exists. Maxwich, they make Aricept, Exelon and Namenda to help with cognitive disorders of the brain such as yours. Ask your doctor today if not being a jagoff is right for you.maxnix wrote:I just love it when owners think they are better engineers than the ones Nissan hired back then.
Maybe not, but I have a skinny 8 year old kid who does.paranoidjack wrote:Hope you have small hands....
Cracks in the fan blade are pretty common. If they're small ones, you can probably ignore 'em.Wiggler wrote:Hey PJ, I think I saw on your writeup way back when you did the complete teardown, that in one of your pictures that one of the white cooling fan blades was broken... what did you use to put it back together? Mine isn't broken, but it's cracking at the hub. I was thinking that a little skillfully applied epoxy resin might fit the bill?
Well... that got me to thinking really hard as to whether or not this method might end up working....paranoidjack wrote:Hope you have small hands....
how big? This big??Brew Q wrote:The one I just sold (a 94) had cracks in the fan - not small ones either, some big ones! This was on a motor with 175k
I have had deep cracks on some of my hubs and I thought one guy had to replace his radiator when a blade came off a few years ago, but memory isn't what it once was.elwesso wrote:I've never seen or heard of a fan coming apart, so I might not worry about it so much.
You just freaked me out dude.Wiggler wrote:PJ.... already ran into this MAF problem
Why the hell did they make a square panel with screws on it that gives the impression that it's supposed to come apart...then surprise!!! three hidden soldered prongs!! WTF???!!!! how can I get it back together? jump the connections with low resistance wire??? I don't want to rely on pressure contact... chassis vibration will force it apart easily....
