Anyone near Dayton OH???
New email:
I don’t think our current version of the fog light module will work with the Altima, but we could most likely modify it to work, if there is enough interest.
I’m not sure how easy the window module will be to install. Nissan is making their doors more and more solid every year, which makes it hard to access the necesarry wires. I’m thinking that you can pull the speaker out and get to the wire, but the service manual doesn’t confirm this.
It would be best if we could find an Altima coupe near Dayton, Ohio to do some testing on. Possilby you can post this request on the forum and see if anyone volunteers. We’ll provide free labor with discounted parts for anyone willing to donate some time.[/email]
He also said he's not sure about the navi from the email. So if someone with factory nav could make the trip, that would be great, otherwise, anyone close hit them up!!
Address is here:
http://maps.google.com/maps?f=...=addrTo email, use
[email protected] or let me know and I can give your contact info to Kevin for follow up.
He also sent info which I guess would help with the install:
General Power:12vdc - White/Blue at BCM Pin 1Accessory - Violet/Yellow at BCM Pin 30IGN - Red/Black at BCM Pin 70Ground - Black at BCM pin 13 Fog Light ModuleOutput 4 - Green/Yellow at BCM pin 54Input 5 - Red/Yellow at BCM pin 75Fog Light (R) White/Red Pin 86Fog Light (L) Blue/Yellow Pin 87
Window Up Module12vdc - Red/Yellw Pin 1 at window switchKey cylinder - Blue/Black Pin 6 at window switchRAP - Blue/White Pin 10 at window switchGround - Black Pin 15 at window switchLock Actuator – Purple – inside door
Mirror Tilt ModuleReverse - Purple/BlackLeft Up - blue/whiteLeft Down - violet/redRight Up - blue/orangeRight Down - violet/white
SunroofOpen – Green at sunroof switchClose – Yellow at sunroof switch
