Koni + RS*R Race on S14 question
gepeto
Car: 1995 S14
I have just received my Koni Yellow shocks, and I am looking forward to getting some RS*R Race springs soon..
They drop 1.4inch in the drop, and 1inch in the back...
My question is, why that kind of drop, will I need to invest on RUCAs to make rear camber less aggressive ?
Or will 1 inch be a small difference on the geometry and will not affect camber too much?
naed240sx
Car: .....
gepeto wrote:I have just received my Koni Yellow shocks, and I am looking forward to getting some RS*R Race springs soon..
No ruca's or adjustable arms will be neccesary. You will need an alignment, and that is all. I do suggest investing in some front pillowball mounts to run more front camber, and adjust the eccentrics in the rear to provide more camber than stock.
BTW, thumbs up for getting some good springs with decent rates.
nismofly
Car: 89 Nissan 240SX Hatch
and the right shocks to match those good springs
what he said about the alignment though, youll be fine
gepeto
Car: 1995 S14
Well I still don't have the springs but thanks, I won't settle for less
What do you recommend for front pillowballs? Is it expensive?
I do not want to run MORE camber as I drive it daily in the summer..well unless I get tires that I can interchange between left and right I guess..
naed240sx
Car: .....
gepeto wrote:Well I still don't have the springs but thanks, I won't settle for less
Camber plates are not that expensive. I don't have a link for you, but I am sure somebody can post one up for you. Considering that your car is stock, you are probably only running 1 degree of camber or less. You can run twice this with no tire wear problems. Bad toe settings is what kills tires. At any rate, pillowball mounts will allow you to change your camber easily and quickly. When I go up to track days for drifting, I run as much camber up front as possible with my pillowballls(Around 4 degrees I think). Afterwards, I put them back to like 2 degrees to drive home. It takes about 5 minutes to adjust them.
gepeto
Car: 1995 S14
I don't know why I thought the shock had to be removed to set the camber, even though I remember seeing people adjusting it. Thanks.
I will look into pillowballs before installing the whole thing (still got 2 months left or something)
hannibal
Car: Red Line to Glenmont
Sounds like ou have a good combo. I know the RS-R race springs are quite stiff. Are the spring rates linear or progressive?
The one and only SPL has camber plates for $159http://www.splparts.com/Parts/...t.asp
EDIT: Oops, on second look, those plates are for KTS coilovers. I dont know if they will work with shocks/struts.
nismofly
as far as i know most camber plates will work with shocks and spring packages
those are fairly universal too
id say give them a call, let them know what you have, and see what they say
naed240sx
Car: .....
nismofly wrote:as far as i know most camber plates will work with shocks and spring packages
werd. If those worked, it would be even cooler, because you could use it to fine tune height settings up front.
gepeto
Car: 1995 S14
The springs should be here within 2-3 weeks yay..
290$CAD not a bad price ...I will see for the spl camber plates..
240marcuSX
Car: E34 525i
E46 M3
It is a very good setup indeed, i run koni yellows with the RSR race springs also. IMO its the best setup you can have outside of coilovers.
You will enjoy it.
nismofly
koni yellows with ground control sleeve overs id say would be better
but in terms of traditional spring/shock, this is the way to go
240marcuSX
Car: E34 525i
E46 M3
^ yeah, thats what i meant.
My driving abiliity has almost maxed out my cars setup, pretty soon ill be looking at upgrading to ground controls.
You have to be careful with ground controls, because with the higher spring rates, you WILL blow the konis.
nismofly
thats why you get the konis custom valved
i know guys that, after getting the konis redone, have run upwards of 5-600 lb rates for 2 race seasons
240marcuSX
Car: E34 525i
E46 M3
Yeah, thats true.
I dont know anyone personally that has gotten them re-valved, but i do know some people who havent, and ran 500+ lb springs, and blew them eventually.
Just adding a note of caution, but i momentarily forgot about the re-valving.
hannibal
Do you know of any sponsors that sell the Koni Sports? I checked a couple of sites, but havent found them.
nismofly
tire rack
hannibal
Doh! Thanks Chris...
gepeto
Car: 1995 S14
OK so here's the word on the SPL Camber plates..
They will work if you get a 30$us adapter that comes with the coilovers usually.
I know I should get them...but my budget is getting tight (moving in Condo in July..)
So I don't know..we'll see..
hannibal
You can always add them later in the summer...
gepeto
Car: 1995 S14
I'm a big fan of the "Do it once do it right" line of thought. If I take all of that apart, I'd rather not have to do it again so soon..
hannibal
My point was you could add them at a later time, but I didnt consider having to remove everything again. Definitely not something you wanna do every weekend.
gepeto
Car: 1995 S14
Hah, received my springs.......they shipped me RS*R down springs instead of race...argh..
PencilShavings
Car: '91 240 hatch
nismofly wrote:koni yellows with ground control sleeve overs id say would be better
those ground control sleeves are good?? i have themin my s13 (just bought it last summer), i have yet to check what shocks are in it, but i want to say agx..
anyway my car bounces around everywhere... and ontop of that over bumps where the tire falls away from the car, the spring usually comes off of the perch, and make a horrendous noise when it comes back together.
i think part of my bounciness is my tires though, crappy 195/60 15's. wheels and summer tires are first on my list this summer after i get out of school and get a job. so once i get tires will i notice a big difference and actually start to like my suspension?
another question i had was with real coilovers can the spring fall away from the perch or are they somehow mounted?
sorry for the threadjack
hannibal
ahh, I dont think the spring is ever supposed to leave the perch. I'm trying to understand how thats even possible. I guess if the springs were too short (meaning they were made for a completely different car) it could happen.
nismofly
PencilShavings wrote:those ground control sleeves are good?? i have themin my s13 (just bought it last summer), i have yet to check what shocks are in it, but i want to say agx..
thats not the ground controls, thats the dampers youve got them on, and the way youve got them set
PencilShavings
Car: '91 240 hatch
alright thanks
ill have to look into it more, i havent had much of a chance yet
as for the springs leaving the perch..it seems like the springs are just very very stiff and the tires give, so over certain bumps it feels like it really bounces up.
nismofly
you really need yellows to run them
you dont even know the rates of your sleeve overs?
PencilShavings
Car: '91 240 hatch
nope, bought the car last summer 2 weeks before i left for school, then put it away for the winter.. i prob havent even driven it over 1000 miles yet
gepeto
Car: 1995 S14
Maybe you have some GR2 shocks?
