Koni + RS*R Race on S14 question
PencilShavings
Car: '91 240 hatch
gepeto wrote:Maybe you have some GR2 shocks?
I do, nice guess
Im not sure why I was thinking agx..anyway I checked this weekend and I was just about to post that they were gr-2's
gepeto
Car: 1995 S14
GR-2s are basically stock replacement, I would say they are not good dampers for stiff springs. That is probably why it's feeling bouncy..
PencilShavings
Car: '91 240 hatch
Agreed, as soon as I found out what shocks they were I looked them up and saw they were only 15% stiffer then stock..
I'm pretty sure my ground controls are at least twice the stock spring rate..great combo
gepeto
Car: 1995 S14
Hey, at least your GR-2s will be gone in 5000miles so you'll have an excuse to upgrade haha
PencilShavings
Car: '91 240 hatch
lol, yes indeed. Im not sure how many miles are on them right now, but when I worry about bouncing off the road over every bump its an excuse to upgrade too
I won't take coners very hard right now cause im afraid one bump mid corner will send me flying.
naed240sx
Car: .....
In order to run ground control springs properly, you MUST have custom length koni dampers. Otherwise, you are gonna be sagging the spring, and giving yourself very little compression travel, and a non captive spring at full droop.
gepeto
Car: 1995 S14
I had a highway accident due to a bouncy suspension (wasn't me driving but was my beater..)
I say fix it ASAP, bouncing = freaking scary and dangerous !!
PencilShavings
Car: '91 240 hatch
naed240sx wrote:In order to run ground control springs properly, you MUST have custom length koni dampers. Otherwise, you are gonna be sagging the spring, and giving yourself very little compression travel, and a non captive spring at full droop.
How much are custom?
If GC emails me back and my rates are what I think they are from the numbers on the springs, I think I'll be looking into rsr race springs this summer with either yellows or agx's.
on a side note, do the rsr race springs blow out yellows and agx's? whats a ballpark cost for getting them revalved?
gepeto
Car: 1995 S14
I think the RS*R Race might be a bit stiff for the AGX but on the yellow it should be well within specs..
As for getting Konis revaled...I guess it goes from 100$/shock to 999999$/shock...hard to say !
gepeto
Car: 1995 S14
How would you set the Koni dampers to go with the RS*R Race springs? Is there a chart of how many clicks on the damper should be matched with what kind of springs (in theory at least) ?
