Hey all, I've posted here before and I'll put in my original post's link into here. topic596760.html
Now my main question for this post is about Fuel Air Ratio's and how everything performed. My car starts and idles fine, and operates as it should BUT! My A/f ratio is at 14.7-.8 at ALL TIMES. From idle to full post. I need to know why it's always at 14.7 while building boost and why it doesn't become more rich as I hit my peak boost. If you read my original post I linked in, you can get the full low down on my specs and issue.
The only thing off hand I haven't replaced yet is my o2 sensors to see if it does anything, but I wanted some Input from you other drivers and try and acquire some knowledge on how the system works and what symptoms I'm having with my engine. I really do appreciate it
--cheers
