I have an SR with a decent build
-gt28r
-big intercooler
- isis Intake
- 740cc injectors (red)
-SplitFire Coils w/ new plugs.
145+ psi in all cylinders
(Not sure of upgraded cams/pistons)
3in turbo back straight pipe.
Isis radiator W/ 2 fans
Electronics-- Apexi fc tuner w/ commander. Apexi electro boost solenoid. Running off a MAP system. Wide band + boost gauge.
I've done a lot of maintenance on this car since I purchased it. Fluids all round, gaskets from iaac to down pipe. Nothing within the engine though. New turbo and oil/fuel/ vac lines. (I like to maintain, especially a worked/beat vehicle)--enough ramble--
Car starts (cold start) and hovers around 2k then blips up and down until 1100 +- at operating temp. When I switch my fans on she's goes to 900-1000. Give her a tap of gas and she drops down around 700 rpm and then catches herself and goes back up.
-Gauges
-- 21~22 vacc
-- a/f 14.7~.8
--boost gauge works as it should
Now! While driving, she takes off fine minus the slight decline in rpm's at initial throttle. Goes through gears fine. My main issue is when I'm cruising at whatever boost I set, it will reach that number and I can hold it steady at 10-21 lbs and when I try and give it just a tad more gas she hits a wall, bucks sooo hard. It's like fuel cutoff cause there's power then absolutely nothing(extreme buck) then back to power. The power loss I'd say is about .5 of a second. Now with my A/F ratio it is ALWAYS at 14.7~.8 (at idle too full boost) it never changes. And after the bucking(granted- I DO NOT keep forcing my engine to go into that motion, just when I know when it's gonna happen and when I give a touch more gas) she's goes back down to idle fine.
After going through test drives and minor tweaks I have some important questions- I took out my o2 sensors one day and of course they were black, I cleaned them off with brake cleaner and through them back in, checked plugs and they burn PERFECT(gapped at .028) I turn the car back on and she fires right up (cold start) and stays strong at 2k with no blips at all, and then drops down at operating temp. Tap on the gas and she just goes up! No drop in rpm or stumble. BUT! Same issue happens when I hit my peak boost(extreme buck)
One more Q. Since I have an electro boost solenoid with mechanical waste gate. My theory is when the computer reads the pressure it's building (whatever the boost psi is set too) then it reaches that level it tells the solenoid to open and that goes straight to the waste gate and she fires right open- with this theory is that the reason I'm getting the extreme buck? I haven't determined what rpm it happens at because it only happens when it reaches the set boost pressure. Now I can drive the car fine when I pay attention to the boost gauge. Shifting right before the peak boost number. Decel situations are fine and normal- I do get a couple back fire pops/flames-- o2 sensor issue? But otherwise she drives awesome!! * apparently the car has been tuned from previous owner at AP tuning in PA. Rated too 313hp at 15.75 boost. I would LOVE to experience the car at it's full potential. In the coming months I'm saving g up to bring it to a tuner (Texas area- hour south Of Houston) to get her checked out. But I figured I'd drop some info at this forum too see if I can get some additional help. I've searched the internet and forums all over and I haven't found anything close to what I'm experiencing- things I've come across as possible issues from other ppls issues -- coil packs/plugs/ o2 sensors/timing/vacc leaks/etc etc. I've gone through the car a lot. I know my BEST bet is to bring it to a tuner and have them go through it
*ive brought it to a tuner back home in New York, but I had a horrible experience- wasted money with no results and a months worth of waiting for answers- wasn't impressed one damn bit!
-- told you it was gonna be a long one. Thanks for your time and I would appreciate some honest important advice/tips
This is my first turbo'd car, I wish it had a carburetor
Cheers
-Rusty
