Agreed whole hearted.yRosco wrote:OH NooESSS!!!! Do Not Risk Your Motor!!! Do a Search and you'll get more answers....Seriously do not buy vital engine parts that are knock offs.....and yes the oil pan is a vital component to your engine.
linky or details on the parts you bought? edu?hpmachine wrote:I just put an oil cooler in my car and avoided the whole oil pan thing. I was warned against those knock off pans anyway but have you read up on how hard it is to get the pan off the engine if it is still in the car? I built my oil cooler with about a 100$ worth of parts off ebay and it took me 2 hours to put it in. I can now run my a/c and cruise at 75 in 90 degree weather and not worry about anything. It dropped my oil temps by about 15F. In my opinion the pan is not worth the trouble unless the engine is out of the car.
a company called Mocal also makes these sandwich plates but you have the option of getting a thermostat built in that way you dont over cool the oil, I have one on my can, Im running -10 ss linies and a setrab cooler, it does a great job of keeping the oil cool, but I still want a Greddy pan to raise the oil capacity and reduce the risk of starvation due to high G turns.hpmachine wrote:Sure... I bought one of these-http://cgi.ebay.com/ebaymotors...photo
and then I found the cheapest 24 row oil cooler that I could. I believe it was a 'dana' 24 row. it was like 45$. Then I spent about another 20$ on some decent hose and fittings. It doesn't look as pretty as those stainless steel setups from greddy but it does the trick for 1/3 the cost. I stuck the oil cooler behind my intercooler
no linky anyways if its a fake dont bother, go real or go home.supreamS14 wrote:how bout this 1 [IMG][/IMG]
Lower oil pan is a separate unit from the upper oil pan. The greddy oil pan is the lower piece which is held on by 10 bolts and comes off in less than 30 mins.hpmachine wrote:I just put an oil cooler in my car and avoided the whole oil pan thing. I was warned against those knock off pans anyway but have you read up on how hard it is to get the pan off the engine if it is still in the car? I built my oil cooler with about a 100$ worth of parts off ebay and it took me 2 hours to put it in. I can now run my a/c and cruise at 75 in 90 degree weather and not worry about anything. It dropped my oil temps by about 15F. In my opinion the pan is not worth the trouble unless the engine is out of the car.
