This actually seems to be the case but the rockers were prevented from dislodging by the RAS. It makes sense since there are different width scratches due to uneven height in the guides and shims. The only lobe that was shiny like a mirror was the last one on the exhaust side. All the others were scratched in different patterns. Thanks for the insightNeil wrote:Hi Narc. Kudos for your thorough investigation!
The additional cam lift of your 260's shouldn't make the head any louder. The rockers should ride on the lobes the same way they do on the stock cams. They should with heavier valve springs, anyway... but if stock springs were re-used then any unusual sound you'd hear from running higher lift cams would come from valve float causing a valve to get munched and/or rocker to become dislodged. That's obviously not your case, though.
I will let everyone know if the noise problem is solved when my cams come in. Hopefully people will read this thread and go run the tests and inspect everything that we did.
