Neil »
https://forums.nicoclub.com/neil-u15642.html
Mon Sep 15, 2008 10:15 am
Ahh.. Check on the underside of your valve cover. Does it look like the chain has been hitting it? Unlike the service bulletin for KA24DE's, that guard between the cam sprockets needs to stay in place.
There are 2 more guides and they are both behind the oil pump cover. Looking at the front of the motor, to the left there's a curved one that pivots at the bottom, that's the tension side. There's another guide on the right, and it is straight.
It is possible that if you only recently started hearing the noise that your chain tensioner is starting to go bad, and the slack is allowing the chain to flap and make contact with the underside of the valve cover. Luckily the tensioners are very easy to replace. It looks like a cap held in place by two 10mm bolts just below the cylinder head on the left side. Nissan has revised their design like 3 times since the early '90's. USDM SR20DE's use the same piece so if you order one for a G20 or something it'll be the right part.
I'd recommend replacing it anyway even if it ends up not helping your ticking problem. They operate with oil pressure and age/sludge will prevent them from applying enough tension on the chain.
As far as the rockers are concerned, I think a tiny bit of side to side movement is okay but if you find any pivotal movement, as a result of any gap between the pad that makes contact with the cam and the cam itself, then that would describe what I was thinking the sound could be. Then again, that's probably an unlikely scenario because supposedly if the rocker is allowed to float at all it will immediately dislodge itself and ruin the valvetrain. which would be why aftermarket rocker arm stoppers exist, since increasing the redline without upgrading valve springs introduces the risk of valve float.
Modified by Neil at 9:27 PM 9/15/2008
