knock sound when braking
matty boi
Car: '93 Nissan 240SX vert
i just bought a 93 240sx convertible in very good condition for 2500. and at low speeds (like 5mph or fewer) it makes a knock sound when i brake, kinda like a tap. it only happens at low speeds. could i get some tips for things to check?
Modified by matty boi at 8:16 PM 11/19/2008
adrianfromthecastle
Car: 1992 Nissan 240sx
matty boi wrote: could i get some tips for things to check?
try to find out exactly where that sound is coming from. Engine bay? front suspension? rear suspension? how hard the sound?
drftman
Car: 97 240sx 95 240sx
subframe brake pads suspension any number of things
matty boi
its coming from the brakes, like there's play in the front suspension or something, its just like a tap like when you knock on a door.ill try to make a video of it soon.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Does it only happen once per braking application, or does it repeat as you hold the brake pedal?
You may have loose tension rod bolts, or a bad tension rod bushing.
matty boi
once per braking application. i think you may be right about it being the tension rod.
heres the video:http://www.youtube.com/watch?v=ut5dxRnkyEs
Modified by matty boi at 7:51 PM 11/26/2008
moso240
Car: Ferrari V12 Powered S13
same thing happened to me turns out the clips snapped and needed replaacement...like 50 bucks
IanS
matty boi wrote:once per braking application. i think you may be right about it being the tension rod.
Why'd you remove the video?
matty boi
i got it fixed thanks flatblackian, turned out it was loose tr bolts.
IanS
Glad to hear you got it fixed.
