240dk »
https://forums.nicoclub.com/240dk-u63124.html
Sun Jun 01, 2008 8:58 am
I just recently replaced my sr via long block. Intake, turbo exhaust sensors are all the same as before. The engine now runs really rich, iv set the timing a million times and it wont even idle normal, it sounds like its missing every now and then but I dont believe it is. If i hold it at any rpm its rough, but seems to rev fine. I checked the ecu and im getting a code 34, knock sensor. Do I need to replace the knock sensor or do I have another issue causing engine knock? I cant seem to get the car running well, I have to change out the plugs every few days because it runs so rich. I also have a fat 02 sensor in a redtop, and dont know if that is causing a problem or not but it didnt run bad before. any help would be greatly appreciated.
