Knock Sensor
S13Ka24e
Car: Tunning, reading, learning
Does the ka24e have a knock sensor or is it just the ka24de?
jrc90240sx
I belive it dose not, about 90% sure
piratepete
Question kinda related to this one: if the kock sensor is disconnected or is malfunctioning will the ecu automatically retard the timing a lot? If so, by how much?
jrc90240sx
I would belive that if it was disconted, it would though a code, and not really afect the car. if it was malfunctioning, there is the posabilty it would retard the timeing back.
S13Ka24e
Do you know if i could add a knock sensor?
d240t2
No, if the knock sensor is disconnected, it retards the timing to be safe.
The knock sensor on KA's is junk...the factory ECU ignores it above 4K rpm anyways because it isn't reliable. It isn't meant for tuning or detecting high-hp knock.
Dennis
E Dogg
Car: 1997 M3 sedan
1988 TII RX-7 10th AE
1990 Ford Bronco XLT
so this is why i dont have power until 4 or higher .... i suspect my sensor is bad
Thee 240sx Owner
Car: Canadian 89 240 with LSD/stock no ac/ and 4 motor swaps
S13Ka24e wrote:Does the ka24e have a knock sensor or is it just the ka24de?
No it does not... i know for sure... and also the KA24E controls timing through the distributor..
E Dogg
Car: 1997 M3 sedan
4 motors huh? thats more than my frinds who drive rx7's haha
Thee 240sx Owner
ya its funny you say that... i run the website in my sig and someone posted the same thing.. "you go through more motors than the whole rotary club here" lol
Exar-Kun
Car: 2005 350Z
E Dogg wrote:so this is why i dont have power until 4 or higher .... i suspect my sensor is bad
I had that problem, I lost 12hp in the mid RPMS bercause of it...you can wire in a balast resistor to the knock sensor, so it reads "normal" to the ECU, but if the knock gets outa of hand, it will still retard the timing...\use good gas.
also, just to not,e with stiff ejgine mounts, apparnetly tht eknock sensor picks up more engine vibration and can be prone to retard timing on you, even with no problem..
-chetalso, I know a guy that wne tthrough 6 DSM 4g36(?) blocks or whatnot....baka. lots of boost and no buildup means blown motor...
Nismo1182
Car: Z06
can you unbolt it off the block?
My motor hits a dead spot sometimes around 4-5k rpms and it gets all sluggish.
Plus the thing you said about the motor mounts might make sense too. I have Nismo mounts, they are stiff but not too stiff.
180fan
Car: 89 fastback
you can unbolt anything. It's just a matter of whether or not you want to live with the check engine light. also the 24E's do NOT have a knock sensor. I can tell you first hand they do not.
Nismo1182
Car: Z06
I mean, all thats holding the sensor to the block is a 10mm bolt. Will unbolting it cause the same effect as unplugging and having it go into some sort of safe mode?
Is there a way to ground it out like on the new sentras?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
just unplug the connector for the Knock Sensor harnes on the front of the motor and put a resistor in it to trick the ECU into thinking everything is all right, oh and dont use crappy gas.
