qship96 wrote:Are you saying you have had the plenum off 2x now in the last 4,000 miles?
ok ok, i had taken the plenum off about 5-7 times in the last 4k miles, a lot if you ask me... didn't exactly replace ALL of the hosesgasket but the ones that I cut or was cracked I have replaced, probably ,should have replaced all of them, not the best mechanic or solution but is that part of the problem??
not taking care of the hoses underneath the plenum is that a bad start?? i just want this car running for a DD but it seems like everytime i drive this car or have something repair on it, something else creeps on behind me and bite me in the A$$..... a few weeks ago i had a code 33 and 34 (o2 and KS), i gotten as far as the KS and found out that the wire was corroded, so I cut and spliced the wire with a new wire (12 gauge i believe) and replaced both KS with the new ones... I also replaced the Y pipe coolant hoses above the KS, and put everything back into place.... started the badboy up and it ran but once you step on the gas it would burp and not wanting to go anywhere but only slowing down.... rechecked the codes and it reads 55=systems ok??? wtf ok my *** and the engine light is still on??? tell me that??
now I do hear that humming from the trunk, not loud but if i listened to it carefully, i can hear it... i figure i should replace the fuel pump since that can be the cuz of the acceleration being bad.... right??
just for the NICO members, I don't have a garage, i live on my own and yes i have been guilty on taking shortcuts with my amazing "Q" (even tho it is giving me a **** load of headaches i still love it), as much as i taken the plenum off (5-7times in 4kmiles), should I just replace the car or just replace the recommended hoses on/below the plenum??
on the fuel pump, can i just buy a walbro 255 lph fuel pump and customize it to fit my car or should i stick with OEM parts $370 freakin dollars and call it a day?? if someone on here had done an walbro fit please let me know how......
any after thoughts and advice would be appreciated..
Thanks,mitchell
