maxnix wrote:I guess you could ohm test it for the expected KS values.
No values from the knock sensors while the new ones had 560 ohms.
To do this way you need to have two specials tools that I did not have when I started:
10 and 12 mm ratcheding wrench for the hose clamps and fan blade and 1/4" socket wrench with 12mm socket for the drivers side knock sensor.
I actually did not remove the inner hose - most people cut it out and bought new ones. I just removed the clamps since they were in the way.
Man I miss working on 4 bangers.... ah good old days working on the '84 Celica.
Got to go back to reassembly.
Tomorrow - spark plugs...
