ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Tue Aug 31, 2010 12:53 am
My old 500whp SR developed a rod knock that wasn't present at idle or low loads. I disabled the injector for that rod's cylinder on my haltech while loading the engine, and it would stop. When I disabled any of the other 3 injectors, the knock would stay present under medium and higher loads over 4k rpm. I didn't believe it was a rod knock either, and the knock slowly got louder over time and later became present even at idle (pulling it's coil would stop the knock). 500 miles later upon pulling the motor, yep, bearing #1 was scored along with the crank. Total miles on bearings, 4000. For me it was probably my rod bolts stretched past their limit. I did replace the rod bolts and new rod bearings with a new crank, and the motor still kicks after 20k miles to this day. Moral of the story, rod knock isn't only at idle. It has freak cases where it doesn't show itself at idle/low load until it is too late. I should have pulled my oil filter and chopped it open when I first heard it at high load, and it possibly would have saved me from a new crankshaft. The filter was full of the metalic flakes from the culprit rod bearing.
