Thats exactly it. New cars are unlikely to be harmed.heywier427 wrote:althogh im not up on the subject, the more % of ethenol in the gas eats away the coil coating in the injectors, is that semi accurate?
so is this only going to hurt our cars, (G50 ect.) or will this include brand new 07 cars as well.
Wouldn't it be easier to recreate the injectors in the aftermarket with upgraded plastic?viso wrote:This can only me one thing in the long run: Guys, we're going to have to go electric if we want to keep driving our Qs.
Electric conversion is an option. Basically, you dump the engine, exhaust, and gas tank. In their place, you install an electric motor, controller (to handle speed), a template to mate the motor to the transmission, a few bits and pieces, and a whole pile of batteries.
Actually it does and the reason there is lessened fuel economy is there is less BTU energy per unit of volume, hence less power also.Jesda wrote:Ethanol doesn't affect power at all. It does affect economy and puts stress on fuel system parts that aren't designed to handle it.
That isn't an accurate statement. Ethanol is a higher-octane fuel, which means high-compression engines can achieve more power than with gasoline. Current flex-fuel E85 vehicles have a compression ratio low enough to handle gasoline, which fails to take advantage of the increased power available from ethanol.maxnix wrote:Actually it does and the reason there is lessened fuel economy is there is less BTU energy per unit of volume, hence less power also.
Yes it is accurate. While ethanol will boost octane and allow higher compression ratios, it still has less BTU per unit volume than gasoline.Jesda wrote:That isn't an accurate statement. Ethanol is a higher-octane fuel, which means high-compression engines can achieve more power than with gasoline.
Ethanol allows an engine, designed to fully take advantage of it, to produce more power from the same volume of fuel. Decreased mileage, but more power per gallon if the vehicle is designed to use it.maxnix wrote:Yes it is accurate. While ethanol will boost octane and allow higher compression ratios, it still has less BTU per unit volume than gasoline.
Quite impossible if the BTU aren't there.Jesda wrote:Ethanol allows an engine, designed to fully take advantage of it, to produce more power from the same volume of fuel.
You start to see gains when a vehicle is properly designed to use ethanol to its full potential.http://www.popsci.com/popsci/a....html"Running straight gasoline, the engine produces 148 horsepower, but E85 jacks it up to 184, with no penalty in fuel economy."maxnix wrote:Quite impossible if the BTU aren't there.
As one of my good attorney friends says, "At no time in law school did I ever hear the words, 'Now ladies and gentlemen, take your calculators and...'"
