kill switch
underground_army
Car: Nissan 240sx 1990
thats pretty screwen tight so thats like the ultimate kill switch lol
SirSilvia
Car: Sold both my babies
wantz87 wrote:is that stock in a car or is that an aftermarket thng? that's friggin BA!!!
i think that was in a concept car. still possible though, like a keypad starter kill, with out the specific signal sent to the receiver the receiver wont kick the relay or w/e to tell it to start. that would be pretty sweet.
underground_army
what kind of switch should i get like the amp volt max cause i dont want to melt **** out lol
underground_army
anybody?
Broadfield
Car: 1992 240sx
You can use any switch you want. If it's not rated for the current draw then simply wire a relay.
underground_army
ok ty
underground_army
well i finally installed the cig lighter as the kill switch and it works i ran it for 3 hours and it did not get hot at all
SirSilvia
nice man yeah there's got to be a constant 12 volts going through it to get it hot. assuming you made it the clutch switch kill it only needs contact till you start it then there's no thing (or close to nothing) going through the line anyway. plus you'd have to hold the cig lighter and clutch in to have anything pass through it.
underground_army
well i installed the fuel pump not the clutch and it wont warm up so its all good in the hood
rsagen
Car: 1989 240SX Coupe 5sp SOLD
1989 240SX Hatch auto SOLD
1990 240SX Coupe auto WRECKED
1990 240SX Hatch auto
1990 Jetta Turbodiesel 5sp FEILD BAGGED
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
underground_army wrote:well i installed the fuel pump not the clutch and it wont warm up so its all good in the hood
A friend of mine did this however it was on an old Chev pickup. It should still work. On your distrubitater... there is a power wire going to it so it can power your spark plugs. Simply put a switch between it, place it under your dash or where ever. So if you leave the switch on its normal, if you turn the switch off, the vechile will not fire.
This has many pros rather then using a switch on your starter wire. One is that if your car is standard, nobody can push your car, pop it into gear, and drive away. The vechile just wont run.
Redevil
An easy way to do it with the nissan button would be to install a simple push button toggle switch behind it. To wire it up you can cut the clutch interlock switch wire and have both ends going to the switch. This way you have to clutch in and push the button at the same time to start the car.
