"All this means is that the 240sx suspension isn't as good as we all think. Suspensions designed for superior handling are SUPPOSED to gain negative camber as they compress to keep the tire contact patch as flat as possible on the ground during hard cornering."
....a well-done suspension should GAIN negative camber when its compressed? thats a fuction of suspension design, and camber settings are a function of chasis engineering....
you honestly think some guy making a ferrari 575 maranello goes "oh man, I better set this up so it gains negative camber if someone lowers/compresses it, thats the sign of a great suspension" most guys, like lotus engineers design the suspesion so whatever settings you lock in stay that way...
I mean, honestly, when a race car enters a turn, the chasis wont flex much, thusly the springs dont compress, and the camber settings DONT CHANGE. you dont want them to! ideally, you'd set the camber to the conditions you want, and it would stay that way, because suspension settings changes cause the car to feel les-slinear, and if the car was properly setup in the first place, then the settings change, it will handle less aptly...
on a side note; jookmasta: nice setup, I would like lower offset wheels, but if you're cool with it, it looks nice...but you wont be clearing coilovers or Z brakes
-chet
