keypad on driver's door
kansjfr
Car: 2001 Q45 base
Maybe I haven't looked as thoroughly an I need to, but I have a keypad on the driver's door of my newly-acquired 2001 Q45, and I don't know how to operate it or find out or change the code. I can't seem to find anything in the owner's manual, either. Any suggestions/instructions would be appreciated. Thanks, Mike.
Q451990
:welcome: to NICO!
Can you post a picture of this keypad? I don't think I've seen that option before... I wonder if it's aftermarket?
kansjfr
Car: 2001 Q45 base
I took a picture on my phone, somehow got it loaded on the computer, but haven't yet figured out how to get it on this forum. Maybe my son can help when he's not busy.
EdBwoy
kansjfr wrote:I took a picture on my phone, somehow got it loaded on the computer, but haven't yet figured out how to get it on this forum. Maybe my son can help when he's not busy.
I recall earlier Nissan Maximas having a row of buttons on the door so I just googled "1991 Nissan Maxima Keypad" and briefly looked at some links that came up on how to locate themaster reset code. I think your picture would help, and maybe a locksmith would be able to tell you who makes the pad if it is aftermarket. Usually the installer's contact information would be somewhere in the car.
I am just as curious about this keypad. I am willing to post your picture for you, if it would save you some trouble.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
We have an incredible SEARCH feature on this forum.
How-to Upload Images Using Imgur
How to post pictures using photobucket
1) Log into your photobucket account.
2) Click on one recently uploaded picture. (You MUST post them INDIVIDUALLY.)
3) On the right side of the screen you'll see SHARE LINKS (see image below).
4) Left click on the box next to IMG. You'll see a confirmation that it copied the link.
5) Paste as a reply in this thread. It's already formatted with the correct tags.
6) Click the submit button.
kansjfr
Car: 2001 Q45 base
EdBwoy, I tried to contact you via private message through this forum, but got a YouTube screen. I was hoping to send you the photo of the keypad, and you could post it on this thread. If you could private message me your email address, or your phone #, I could email or text you the photo. I apologize for my computer ineptitude. Thanks, Mike.
EdBwoy
No problem, I'm glad to help. Why go through the frustration if you're not going to be posting many pictures?
I PM'd you
kansjfr
Car: 2001 Q45 base
EdBwoy, this site has thoroughly confounded me. I've tried everything I know and have been unable to retrieve your PM to me. Any suggestions/directions?
EdBwoy
I believe there is a minimum number of posts you need to have in order to send PMs. I suppose the same applies to receiving them?
Anyway, send pictures to [REDACTED]. We'll get thru this
kansjfr
Car: 2001 Q45 base
Ok, sent it to you, should have it by now. Go ahead and post it on the forum to see if anybody knows anything about it. Thanks so much for sticking with me on this. Mike.
EdBwoy
You bet! And I know I requested you take another one in my response, because my phone showed a very cropped image. It shows up just fine on the computer so this works for me. It looks like an aftermarket pad to me.
Here it is: Image
Rogue One
2022 Honda Pilot SE
Aftermarket. There's nothing about door keypads in the owners manual. https://www.infiniti-techinfo.com/refgh ... ti-Q45.pdf
Ditto for the FSM. http://www.nicoclub.com/FSM/Q45/2001_Q45/2001_Q45/
Q451990
I'm going to guess that's an aftermarket unit. I've never seen anything like it installed from the factory on a Nissan or Infiniti. I did some searching, and can't find anything that looks exactly like it - but aftermarket stick-on units aren't uncommon.
kansjfr
Car: 2001 Q45 base
Yeah, I agree that it's probably aftermarket. I bought the car from the second owner's widow. She didn't know anything about it either. I wonder if I can just take it off, and hope there aren't any holes in the door under the keypad, or in the alternative try to find out how it works--codes, activation (unlikely in my estimation).
Q451990
I suspect it's stick-on, with a dead lithium battery inside... that seems to be the way most of them worked.
kansjfr
Car: 2001 Q45 base
So, in your opinion, can I just peel it off, or will it have wires that go into the skin of the door?
Q451990
My guess is that you could peel it off.
