Hot Dave wrote:was the e85 just a simple tune? or did u have to change the fuel lines and fuel pump also?
The fuel system was designed for E85 from the beginning. DW300 supports 600whp on E85 and my 75lb injectors will be the bottle neck at about 420whp at 90% duty cycle at 4 bar base pressure. You either want a full stand alone or nistune if your going 4bar base fuel pressure because JWT and enthalpy tune at 3bar.
E85 takes 30% more fuel than gas. Changing from 3bar to 4bar base pressure increases fuel flow roughly 30%.
75lb injectors=780cc
780cc injectors at 3bar base pressure= 900cc at 4bar base pressure
Don't attempt this without proper tuning!
