The engine is back in and running nice. The oil pressure does not dip low like it did, and it is not running anywhere near as rich. While I had the engine out I went over it thoroughly and found two things that may have contributed to the problem. One, I made a gasket for the AAC valve out of cork paper and it looked to be very cracked up and brittle already. When I unbolted it the paper crumbled away, so I think it may have been leaking there. Made a new gasket with thick black paper and RTVed it good.
Two, somehow I missed the angled vacuum port on the bottom side of the throttle body so I capped it off. Now it idles good, I had to mess with the idle screw on the intake manifold and on the throttle body to raise it up some but now it sits at about 750rpm.
The strange wideband readings were because I had the wideband wired up to the narrowband wire from the control unit. I rewired it this evening, and in the morning I am planning on recalibrating it, putting the dash back together and seeing what I have. It will idle strong without choking up and dying now, and after pulling the plugs they are not wet like before. Hopefully I can drive it tommorrow!
