MinisterofDOOMhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113Keep stuff from sliding around in trunk: suggestions?Fri May 14, 2010 2:40 am
Postby
Dano »
https://forums.nicoclub.com/dano-u2493.htmlFri May 14, 2010 9:40 pm
Chris, in the s14 I had eye bolts and used bungee cords. Worked very well for years.
Harbor freight sells a motorcycle cargo net for $3.00 ... three bux.... cheap.... and it has 6 attachment hooks. I bought one for the bed of the truck to hold my basketball and football from rolling around. Works great. and you'd have less than $7 in it with the eye bolts.
Postby
skydragoness »
https://forums.nicoclub.com/skydragoness-u193.htmlFri May 14, 2010 10:00 pm
I made measurements so I could have a semi-deep rubbermaid-type container for all the liquid stuff, jumper cables, etc. and everything else is held in place with an assortment of plastic cable ties. Also I have a full-size spare so that kind of keeps things from sliding too.
Postby
PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.htmlFri May 14, 2010 10:19 pm
I would also vote you weld in some hooks... maybe weld them to a plate and use some self tapping screws to hold it down... just make sure you don't drill it right into your gas tank. Put the hooks in the corners of the trunk so they wont be in the way of everything else. Then do the aforementioned bungee cording/netting.
Postby
Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.htmlSat May 15, 2010 10:37 am
I basically don't put much of anything in my truck just for this reason.
However I have a canvas road side emergency kit that has Velcro on the bottom, and the bottom of the trunk in the 240 is carpeted... So I stick that thing over towards the corner so it will hold a 12 pack in place.
