ColoradoMountainDiva wrote:Okay! Got two new kayaks and a Nissan Rogue (top model) and am curious. I want to be able to load myself and I am slightly handicapped. I think the side loading hullivator by Thule is my choice, the question is the 2nd Kayak is my husbands who is perfectly capable to handle his boat so I dont want to spend as much on his. My question is what combination of rack would work and fit on my Rogues roof?
I have two Thule 835PRO racks, I got it solely because it let you fold it down when there's no kayak on it. I don't leave the rack on the entire year but it's nice to go camping for a weekend, take the kayaks off the roof and leave the racks on and folded down, not worrying about low clearances, etc. I do wish the shape was a little more "J" at the bottom to hold my kayak better ... the shape fits my Kestrel 120 quite well but not my Merlin LT as "snugly", but never had a problem. I guess if I was really that concerned, I'd cut a foam block out to better suit my Merlin LT. Again, never had any problems.
Yakima has a folding rack as well, the BowDown. I like the shape of that better but my coworker has been comparing the two and was concerned with the Yakima's holding structure being plastic rather than metal. If you check out reviews on REI.com, they are mostly favorable but one person had the BowDown separate due to the plastic giving and that worries me a bit.
Personally, I think the Thule 835PRO would work great for your 2nd kayak.
Here's a pic with both my kayaks on the Rogue using Thule 835PRO racks on factory cross bars.
The Hullivator is great but expensive (almost 3x the price of an 835PRO) AND heavier (I think it's about 30-ish lbs more than the 835PRO). The weight of it may be a concern because the Rogue is rated for 100lbs .... weight adds up quickly when the Hullivator can weigh as much as a kayak! My setup (racks and both kayaks) weigh just a little over 100lbs. Using a Hullivator would have probably put me closer to 150 lbs.
My female coworker (5' 3" ... about 100lbs) used to load her kayak on to an Xterra SUV all by herself. Despite her size (small) and weight challenge of her kayak (it was a 14' rotomolded, probably weighed 60+ lbs), she could do it all by herself using a Thule 847 Outrigger II assist. It's just a simple bar that can slide out the side, so that you can lift one end of the kayak and rest it on the bar, then lift the other end to get it to roof height. I am not sure of your handicap or if this may be an option for you and you can use it with normal racks which are much cheaper than a Hullivator. Here's a video of how it works:
http://www.youtube.com/watch?v=_hH9KTreFIs
Some people also use roller loaders where they just "roll" the kayak one but I think the Rogue is too narrow to load two kayaks flat like that ... maybe one, probably not two. I personally like the idea of the Outrigger assist bar better.
Some options, hope it helps.
