cornuts »
https://forums.nicoclub.com/cornuts-u129553.html
Tue May 19, 2009 7:39 pm
heres some info from california laws on aftermarket parts and engine swaps.. this kinda sound an sr20 or a ca18 would be legal because it coming out the same car just j-spec right!!
Replacement Parts Guidelines - Aftermarket, Performance and Add-On Parts RegulationsWednesday, May 20, 2009 Up LinksPermits, Certifications, etc. ARB Programs Mobile Sources Operators Manufacturers Certifications Aftermarket, Performance and Add-On Parts Local LinksAdditional Information for Manufacturers of Aftermarket Parts Aftermarket Parts Sold in California Replacement Parts Legal Add-on or Modified Parts (Executive Orders Database) Competition or Racing Use Only Parts Auxiliary Fuel Tanks Alternative Fuel Retrofit Systems Application Forms for Exemptions Background Catalytic Converters Contacts Heavy-Duty Diesel Retrofit Device Emission Reduction Verification Join Any Mobile Sources Email List(s) Motorcycle Aftermarket Parts Off-Road Vehicles, Engines, and Equipment
This page last reviewed October 7, 2008
The following list will help you determine if a part for your vehicle is a replacement part and legal for use on pollution. Check the manufacturer's catalogue to verify vehicle application and look for disclaimers, such as "Not legal for street use in California." Air Cleaner Most emission controlled vehicles will have an air cleaner that is a closed element type or thermostatically controlled. A replacement air cleaner must meet the same specifications as the original and connect to any emissions equipment that was attached to the original equipment air cleaner. Any replacement air cleaner elements may be used as long as they meet original factory specifications. Any air cleaner that does not meet the original factory specifications requires an Executive Order to be legal for street use. Cams The manufacturer of replacement cams determines which of their parts are considered replacements for original equipment. These replacement cams are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. A replacement cam must have exactly the same specifications (grind) as the original part. Cams that have different specifications than the original part require an Executive Order to be legal for street use. Carburetors The manufacturer of replacement carburetors determines which of their models are considered replacements for original equipment. These replacement carburetors are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Carburetors not listed as replacement parts by their manufacturer must have an Executive Order to be legal for street use. Catalytic Converters A legal aftermarket catalyst is one that is listed in an ARB approved manufacturers catalogue for the year, make, model, and engine size of vehicle on which it is being installed. Manufacturers of aftermarket catalytic converters must obtain an Executive Order for their products from the Air Resources Board in order to be listed in an approved catalogue. Coils and Ignition Wires Any type of coil or ignition wires may be used as long as they meet original manufacturer specifications. Computer Chips Replacement computer chips must be an original equipment manufacturer part. Aftermarket computer chips must have an Executive Order to be legal for street use. Electronic Ignitions The manufacturer of replacement electronic ignitions determines which of their models are considered replacements for original equipment. These replacement electronic ignitions are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Electronic ignitions or electronic point replacement units for vehicles not originally equipped with these items require an Executive Order to be legal for street use. Swapping electronic ignitions from different years, engines, or makes is illegal. Distributors The manufacturer of a replacement distributor determines which of their models are considered replacements for original equipment. These replacement distributors are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Swapping distributors from different years, engines or makes is illegal. Aftermarket distributors that are not listed as replacements for the original part require an Executive Order number to be legal for street use. Fuel Injection The manufacturer of replacement fuel injection systems determines which of their systems are considered replacements for original equipment. These replacement fuel injection systems are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Fuel injection systems not listed as replacement parts require an Executive Order to be legal. Modifications that change a vehicle from fuel injection to carburetion or from carburetion to fuel injection also require an Executive Order to be legal. Fuel Tanks Replacement fuel tanks must be identical to the original part. Add-on fuel tanks, or tanks with greater capacity than the original tank are legal for street use only if they have been issued an Executive Order. Heads Replacement heads must be identical to the original part. Head swaps from different years, engines or makes are illegal. Aftermarket heads or valve train components that are not made to the same specifications as the original parts require an Executive Order to be legal for street use. Headers Non-Catalytic Converter Equipped Vehicles
Headers for non-catalyst equipped vehicles are considered legal replacement parts as long the replacement header allows for the installation of all smog control equipment originally attached to the stock exhaust manifold. Depending on the vehicle, some of the equipment that would normally be attached to the exhaust manifold includes:
Air Injectors
Heat Shields for the Thermostatic Air Cleaner
Heat Risers
EGR System Hookups
Fuel Evaporation Systems Catalytic Converter Equipped Vehicles
Headers for use on catalytic converter equipped vehicles require an Executive Order to be legal for street use. Intake Manifolds The manufacturer of replacement manifolds determines which of their models are considered replacements for original equipment. These replacement manifolds are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Replacement manifolds may be made of a different material than the original part, for example polished aluminium instead of cast iron, but the design of the casting must be the same. Any manifold not listed as replacement part by its manufacturer must have an Executive Order to be legal for street use. Carburetor adapter plates are not legal unless they are an integral part of a replacement manifold. Other Internal Engine Parts Replacement internal engine parts, such as pistons, rods, or the crank, must be designed to factory specifications. Oversize parts can be used as long as they are within factory tolerances for replacement engine parts. Any part not built within factory specifications requires an Executive Order to be legal for street use. Transmission or Transaxle Transmissions and transaxles changes alone are not legal. Transmissions and transaxles can only be changed along with their matching engine. The total engine transmission package must conform to the engine change requirements above. Replacement Engines Entire engines can be replacement parts. As with any other replacement part, the engine must be identical to the original. If the replacement block or engine is obtained without emissions equipment, all the equipment from the original engine must be installed on the replacement block. If the engine is not identical to the original then it is not a replacement part, instead it is considered an engine change. Engine changes are a modification that must meet certain requirements to be legal (please see "Engine Changes"). Japanese Replacement Engines Used engines imported from Japan can be used as replacement engines as long as the engine being used has been identified as functionally identical to the original engine. Please refer to the engine importers catalogue to determine if a replacement engine is legal for installation in your vehicle. Engine Changes Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle: The engine must be the same year or newer than the vehicle.
The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight.
If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
All emissions control equipment must remain on the installed engine. After an engine change, vehicles must first be inspected by a state referee station. The vehicle will be inspected to ensure that all the equipment required is in place, and vehicle will be emissions tested subject to the specifications of the installed engine. Exemptions for Uncontrolled Vehicles Vehicles that were manufactured before emission control regulations took effect are called uncontrolled vehicles. Aftermarket parts regulations and anti-tampering laws do not apply to these vehicles. Uncontrolled vehicles may have any aftermarket add-on or modified part installed as long as the vehicle can still meet the tailpipe emission standards for the year of the vehicle. Uncontrolled vehicles must retain any original or retrofit crankcase control (PCV) devices and NOx device required for the year of the vehicle. The following vehicles are considered uncontrolled vehicles: 1965 and Older : U.S. Manufactured California Certified Vehicles
1967 and Older: U.S. Manufactured Federally Certified Vehicles
1967 and Older: Foreign Manufactured Vehicles For More Information To verify Executive Order numbers, or for questions about the replacement parts guidelines, please contact the California Air Resources Board Vehicle Hotline: (800) 242-4450 California(626) 575-6858 Non-USA To obtain a list of ARB Executive Order parts, or for information on the Executive Order certification process for aftermarket parts manufacturers, please write to:
California Air Resources BoardAftermarket Parts Section9480 Telstar Avenue, Suite 4El Monte, California 91731
Aftermarket Parts Program
Back to Top | Contact Us | A–Z Index Decisions Pending and Opportunities for Public ParticipationConditions of Use | Privacy PolicyHow to Request Public Records The Board is one of six boards, departments, and offices underthe umbrella of the California Environmental Protection Agency.Cal/EPA | ARB | CIWMB | DPR | DTSC | OEHHA | SWRCB
