For an all motor build? i don't think you have to.canyouSAY240 wrote:might want to change the coonnecting rods to forged ones
it just my opinion because i know the rod are cast not forged, iv had a rod brake, but i just have bad luckGabes13 wrote:For an all motor build? i don't think you have to.canyouSAY240 wrote:might want to change the coonnecting rods to forged ones
Keep the fan clutch assembly.240sxAli4Life wrote:who ever told you a header is bad, its not!! They dont know f**king s***!! You may not notice a huge power gain but you will notice torque!! And it makes your engine breath better!! Although to get the MOST power out of a header you need to bore out your block and your throttle body!! And get an air intake for sure!! If your running non turbo i dont reccomend getting a 3 inch exhaust, get a 2.5 with a 4 inch tip!! And a test pipe would be good too!! You dont need to do cam work!! If you do that you will need lots of other stuff inside your engine to keep up with the 1 cam, and you will need a tune!! I had SOHC and when nissan made the SOHC they had torque in mind!! So think of it this way... anything that spins on your engine, if you make it lighter, your car will accelerate alot faster, and decelerate alot faster!! Get a lightweight crank pully, and and a lightweight flywheel! Although with a lightweight flywheel you will take off faster and slow faster from the pushing in or letting out the gas pedal. And you will gain acceleration (bottom end power) but you may loose SOME top end power!! But in racing you need a lightweight flywheel!! And get a 2 inch core aluminum radiator, and get dual electric fans!! Take out your stock clutch fan, it does nothing really lol!! That will give you engine more power, and torque!! What mods do you have on your ka24e right now???????????????
zomg calm down with the !!!!!!!! please.240sxAli4Life wrote:electric fans and aluminum radiator is better!! it cools your engine more!! espessially if your going to turbo your car, or run all motor!
Okay... Lightweight flywheel, and lightweight underdrive pullys are great things to have!! They dramatically increase acceleration and deceleration of your car!! You gain low end power, but your high end power (top speed) stay the same!! But you will be able to get up to speed alot faster!!! (which is what you want)! You said that you havent seen a underdrive pully for the SOHC KA?? IDK where you look for parts, but here is a link to one!! You can click down below for the lightweight pully for the KA24DE or the KA24E!! HERE IS THE LINK BELOW!!Gabes13 wrote:Installing a header doesn't mean you'll net more torque. The power output all depends on the diameter of the piping, the lengths of the primary and secondary tubes, and the size of the collector. All those header attributes will dictate whether a header produces more torque or horsepower and where in the power band they peak.
To increase the revs and powerband of any motor, cams are required. Head work and valvetrain depends on the size of the cams. The kaE motor head is very restricting from the factory so any head work is beneficial. As with any build a tune of some sort is recommended.
A light weight crank pulley should not be recommended because of the excessive harmonic vibrations that occur from long stroke engines. I haven't seen one crank pulley on the market that addresses that issue for the kaE.
I light weight flywheel does not necessarily increase output but rather the throttle response of the motor. The revs may rise faster and drop faster, but it most likely wont dictate your final power output.
Lastly, The stock clutch fan is better than electric fans, period.
240sxAli4Life wrote:You said that you havent seen a underdrive pully for the SOHC KA?? IDK where you look for parts, but here is a link to one!! You can click down below for the lightweight pully for the KA24DE or the KA24E!! HERE IS THE LINK BELOW!!
http://www.enjukuracing.com/crank-pulle ... -6676.html
Wow. You probably read ads and believe all the HP ratings they will add to your car's performance.240sxAli4Life wrote:A 2 inch core alumium radiator is way better than the stock clutch fan mr. doesnt know s*** Gabes13!! Why do you think when you have a built motor everyone does dual elctric fans and aluminum rad!! It will cool your engine alot better than stock clutch fan!! And it will give you more power!! Now do the other things first before putting in aftermarket cams!! Ya aftermarket cams will help, but you need to do more to the internals of the engine to get the most result!! But you have to get your ecu tuned when you put better cams in becasue since the power gain your engine will be using more fluids, and if its still giving is stock than you could burnout your cams!! Its really an all or none situation! Either keep it stock, or do lots of engine work and a fuel tune to run aftermarket cams!! I would keep them stock for now, and do what i said before first!! And putting a header on WILL FOR SURE INCREASE AT LEAST 3 HP, AND MORE TORQUE!!!! IT DOESNT DEPEND!! GET A PACESETTER OR OBX HEADER FOR YOUR SOHC!!
Dude, i have a solid gold radiator with an electric clutch double fan. WAAAAAY better then your lame setup.240sxAli4Life wrote:A 2 inch core alumium radiator is way better than the stock clutch fan mr. doesnt know s*** Gabes13!! Why do you think when you have a built motor everyone does dual elctric fans and aluminum rad!! It will cool your engine alot better than stock clutch fan!! And it will give you more power!! Now do the other things first before putting in aftermarket cams!! Ya aftermarket cams will help, but you need to do more to the internals of the engine to get the most result!! But you have to get your ecu tuned when you put better cams in becasue since the power gain your engine will be using more fluids, and if its still giving is stock than you could burnout your cams!! Its really an all or none situation! Either keep it stock, or do lots of engine work and a fuel tune to run aftermarket cams!! I would keep them stock for now, and do what i said before first!! And putting a header on WILL FOR SURE INCREASE AT LEAST 3 HP, AND MORE TORQUE!!!! IT DOESNT DEPEND!! GET A PACESETTER OR OBX HEADER FOR YOUR SOHC!!
Why dont you just keep your car stock then, if all the aftermarket parts are bad why do they make them??? Why do so many people use them??breadbox wrote:Wow. You probably read ads and believe all the HP ratings they will add to your car's performance.240sxAli4Life wrote:A 2 inch core alumium radiator is way better than the stock clutch fan mr. doesnt know s*** Gabes13!! Why do you think when you have a built motor everyone does dual elctric fans and aluminum rad!! It will cool your engine alot better than stock clutch fan!! And it will give you more power!! Now do the other things first before putting in aftermarket cams!! Ya aftermarket cams will help, but you need to do more to the internals of the engine to get the most result!! But you have to get your ecu tuned when you put better cams in becasue since the power gain your engine will be using more fluids, and if its still giving is stock than you could burnout your cams!! Its really an all or none situation! Either keep it stock, or do lots of engine work and a fuel tune to run aftermarket cams!! I would keep them stock for now, and do what i said before first!! And putting a header on WILL FOR SURE INCREASE AT LEAST 3 HP, AND MORE TORQUE!!!! IT DOESNT DEPEND!! GET A PACESETTER OR OBX HEADER FOR YOUR SOHC!!
I think just replacing the down pipe is better than complete header. With the header and 2.5" you'll have great accel from 3200-5500 but before that you are losing a bit of the low end pep. For most driving I'd rather have more low end pep than a car fun only at highways speeds. I can get 3hp just going cat-back, who cares. If I want hp increase I'm looking for 30+ gains, not negligible gains.
I have a Stock SOHC 89 Coupe for a daily with the stock copper/Brass/Steel Rad. It cools more than fine but I recommend an in line oil cooler for the trans, I am about to do this after it warms up. I also have a BNIB Alu radiator and its the same size but has more cores and cannot bolt up to the auto trans so It'll probably wait til I go RB20.
Clutch fans only do actual cooling during idle. Efans are on alot of cars because they don't know how clutch fans work. Plus the way most people wire them without a thermostat or relay, puts more draw on the system than a clutch fan.
Lightened crank pulleys will get you better gas efficiency but that doesn't mean its better than stock.
On the whole flywheel thing I prefer a stock flywheel, its easier to stay in the power band and doesn't drop revs as quickly. I am wanting to eventually try the white bunny mod, on my project turbo hatch.
Being that this is kind of a comparison thread, here are some things I've noticed between the two motors.
SOHC has more belts, meaning If you don't want an accessory, cut the belt.
SOHC has an external oil pump, so if you are getting into a random 240sx then you can inspect the oil pump with out much trouble.
SOHC has really easy to find injectors for upgrades, like RX-7 injectors pop right in, I think DSM eclipse injectors too.
DOHC has Power steering and water pump on one belt, if this belt gets loose the power steering messes with the water pump and it overheats
On both water pump and thermostat replacement is relatively easy.
Overall they both are very easy to work on and get parts for. Plus they like boost.
Also O&J Performance makes SOHC camshafts and mech lifters if you want them.
