ka24e transmission on a ka24de
LingeringSuicide
Car: 1990 240SX hatchback 1993 240sx Vert
I have a 1993 240 and i am wanting to swap the auto transmission out for a manual. The thing I want to know is will a ka24e transmission fit on a ka24de? Trust me it is a ***** trying to find a ka24de transmission where I’m at, but the ka24e transmissions are plentiful. Thanks people.
shpaintball
Car: 90' SOHC 240sx RIP, 92 DOHC KA project STOLEN 87 FC RX-7 TURBO ...93 KA died...89 SR20 DD..08 Titan new toy
say transmission ....nearly same block...just different head...of course you can use that transmission ...lol
sx_hatch
Car: 90 240sx coupe
you cant use that transmission ive tried dont waste your time
shpaintball
i did...worked fine ...i can show you a write up if you like
93HATCH240
Car: 1993 NISSAN 240SX HATCH
I used a manual transmission from an 89 and it bolted up pefect to my 93 de motor.
shane_lxi
Car: '71 Datsun 521, '89 240sx coupe, '90 240sx fb, and 2 s13 shells
I am actually in this same predicament, that write up would be nice if you didnt mind hooking it up shpaintball :D.
dRiLstar
yeah that write up could be useful.. with everything u need and stuff thx
Florida240sx
WTF? Why you need a write up? Unbolt transmission...bolt transmission back up. Done it 3 times now.....
jyv
Car: 1989 Nissan 240sx Fastback
Like everyone has said...Yes, the 89-90 transmission does Fit for 91-94 Dohc Engines. Currently right now, my 91 Dohc engine has an 89 transmission that was rebuilt.
93HATCH240
I currently have a 95 motor in my S13 with and trans from an 89. everything bolted up correctly but with the trans in 1st or any gear when i let off the clutch pedal right where the clutch engages or disengages i hear grinding. I know its not the transmission. I know what synchro grinding sounds like. I'm at a loss.
dRiLstar
florida u need to shut the **** up..
dickie
Car: Killer Turtle
dRiLstar wrote:florida u need to shut the **** up..
careful with the words, Florida240sx is 100% correct. if something isnt working, you're either overthinking it or theres a problem with the parts youre using. make sure you have a MT pilot bushing in the crank.
dRiLstar
im not saying me im saying for other people that read this and want to try it theirselfes.. a writeup would be nice
dickie
Car: Killer Turtle
here's your writeup:
get your extensions and universals out. unless you are pulling the engine and transmission together, you will be sitting on the floor of the garage under your car with your head in the transmission tunnel from about 3 feet back trying to get your socket wrench on the bolts that secure the upper half of the trans. to the block.
get a transmission lift/jack and support it, have a friend there to help you catch it when it comes off.
put a 2x4 under the crank pulley and slowly raise the front of the engine so it is tilted back to accommodate removal. you may be able to get more angle by loosening the motor mount nuts.
remove the starter and set it aside. remove all of the transmission bolts, be careful to keep them in order as they are different lengths.
when the bolts are gone, give it a good tug making sure that your friend isnt UNDER it in case it falls off your lift. if it is stubborn, you can use your rubber mallet to whack it off () or pull from side to side until it is free.
Florida240sx
Get a 14mm wrench and sockets. Remove battery from car before doing anything.Remove shifter from transmission. Disconnect all plugs on transmission. Remove the slave cylinder, held on by 2 14mm bolts. Remove all transmission bolts 14 mm. You with friend and caution pull transmission out.Grab a sohc transmission and repeat process backwards.
93HATCH240
93HATCH240 wrote:I currently have a 95 motor in my S13 with and trans from an 89. everything bolted up correctly but with the trans in 1st or any gear when i let off the clutch pedal right where the clutch engages or disengages i hear grinding. I know its not the transmission. I know what synchro grinding sounds like. I'm at a loss.
dRiLstar
ty sorry i just ****in wild out of nowhere.. happens sry florida
disbquan
I need to find out if there is any problems with a s14 DOHC motor to a SOHC transmission also. Someone help us out.
bone_stock_240
Car: 1995 Infiniti Q45
The SOHC transmission is missing the crank angle sensor, so the check engine light will be on if this is going into an S14. I may be wrong though.
93HATCH240
bone_stock_240 wrote:The SOHC transmission is missing the crank angle sensor, so the check engine light will be on if this is going into an S14. I may be wrong though.
Any other problems besides the crank angel sensor. I have a 95 motor in my s13 and no check engin light is on.
80200sx
Car: 1980 Datsun 200sx, 1982 Nissan Sentra, 2005 Honda S2000, 2000 Honda Civic SI, 1969 Dodge Charger
the only difference between the two transmissions is the bell housing
ncp2g
Car: 1991 Nissan 240sx
I've done it, and it works
vincent_18
Car: 2008 Nissan Versa
so does it still bolt up even though they have different housings?
Kalypso
sorry to revive but...
will a dohc trans line up with a single cam?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Zombie Transmission thread, doesn't belong in KA.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Kalypso wrote:sorry to revive but...
:squint: Yes. only some DE trans have 4 sensors and SOHC only have 3, also the breather tube is a bit different with the tube bolted to one of the top bolts to keep it elevated.
xX RB Xx
Car: SE3P, FC3S, FC3C.
Yes! Just swap the bellhousing. So easy!!!
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
S13 KA trans KA-E and DE are the Same. The trans is the same for the SR and S14 KA witht he exception of the SR bellhousing, and the S14 bell having a hole for the CAS needed for the S14.
YOU CAN USE THE TRANS. You need
Trans
Crossmember
Driveshaft (ABS if you have ABS, non if you dont)
Bellhousing bolts (some of the autos are the wrong size)
NEW flyweel bolts
Clutch kit with pilot bushing or bearing
Slave
CMC
Harldine with or without damper if you plan to bypass it.
Pedal assy with mounting nuts
Wire
And some time
240TKE128
Car: 1990 240sx HB
2011 subaru outback 2.5i limited
Ok, i hate to revive the thread again but, stupid question i know that the individual transmissions could easily be changed but would a clutch/flywheel for the ka24de transmission work with the ka24e transmission/housing.
biggie
Should be fine.
Clutch depends on the engine for mounting, all the 5speed trannies are the same shape for bellhousing and same input shaft.
