SeanC wrote:why not use both? one in the front and one in back. i would use the ka in the back because of the better torque so you can have the sr for the top end in the front. or you could do a side by side to be as much like a v8 as possible.
and the diff, tire size, wheel size, suspension set-up, and amount of rwhpRazi wrote:Drifting longer/shorter depends on the driver's skills.
Please search on this topic. Only reason why I haven't locked this thread yet is cause everyone is very civilized and no flaming has been going on.j u ice wrote:so the kat can handal drifting o.k. and i know all that suspntion sh@!# so howe did thay rank at nope ..
So i guess It's about 50/50 balance... more than torque? if so, then rx-8 would be kickin ***... but thats neither here... nor there hahahah480sx wrote:Theres one issue thats been overlooked, and thats weight distribution. The SR weighs less than the KA and that puts your car closer to 50/50 which is what the pros go for when drifting. However if your not a pro, you probably wouldnt notice this at all. I can tell you i have a SR powerd s13 and drifting is still tricky ^^.
However, these guys are right about the SR and the CA having no low end to speak of. Also, they simply cant produce the torque that a KA can. When you drift you really need to focus on your steering/counter steer, and not so much on the rev's. I would think that low end torque would be really nice when your trying to put your car into a slide, and keep it in one.
Also, the KA-T guys/forum are a cut above
my wife will agree! she has drove my pos in n/a sohc and dohc and turbo piggy style, she didnt even hit 1psi of boost before she , she now has a slight clue as to why....idrum2loud wrote:Why do you need revs?
KA ftw, its what was in the car from factory, all the parts u could want, it has tourqe, sounds awesome, and the ladies love the KA as well.
