singlecamsam>>> well, I have no first hand experiience about swapability, I only know what I know from reading haynes shop manuals and spec charts and internet pages (well, whaddya know, it IS good for something other than p0rn!) but, everyone I talk to says that cranks are interchangeable between nissan Z (motors, not the car) series motors and L series motors. AND the Z series motors and the KA series motors use the same headgasket. so, you can put a L crank into a Z block and top it off with a KAE head. but then again the Z24 is a weak block. blah. I have ALSO read that the KA head will bolt on to a L block if you use a Z series timing cover. so, go get a L crank, they are INDESTRUCTABLE!
hey SIL80drifter>>>>> you stole my idea!! actually I was going to weld 3/4 of a head to 3/4 of a head and put it on my L28ET that I have sitting in my garage, I guess it would be a KAL28ET then? thats the one thing the L6's need is a crossflow head with more valves!!! I mean, hey if a stock short block can push a heavy 280zx to 11.49 in the 1/4, with a side flow head, imagine what it could do with the KAE's flow. I have matched teh headgaskets between the two motors up, its scary how close they are. bore centers, coolant passages, head bolts, oil jet. well,, other than the whole 4 cyl vs 6 thing. All I need to do now is find a REALLY good aluminum welder and someone who makes complete custom camshafts.
sorry for the thread jacking. KAE is cheaper and can be MADE better than the KADE, but out of the box, KAde will make more power. P.S. I just wish the KA24DE head would fit on the L blocks, too bad the KAE's and KAde's are almost completely different motors
McAdam
