demcj wrote:hmmm...right and wrong.
he didn't say KA, my bad.
but the block he's talking about is not from a chevy.
-demetrius
there was a NAPS Z-series engine made back in the day, it was a 2.4L engine that had emissions and fuel economy in mind. I think it came in some family movers, maybe the old 70's Maxima. Can't quite remember, but the pistons are pretty large, you use that size piston when doing a big bore on a L28, along with the L28D crank, which then gives you 3.1L of SOHC L series goodness
as far as which is better, they have their strengths and weaknesses. HOWEVER!!! for those strengths and weaknesses to really come into play, you'd have to be going for EVERY BIT of HP that you possibly could, it sounds like you just going for cheap and easy, and it's gonna be daily driven, so it's got lower HP, therefor I'd suggest the SOHC, since it's more readily available and the parts are cheaper.
you must look at your power goals before you can figure out what is better. I like the CA18 over teh SR20 since it's nearly a grand cheaper for a front clip, and with low power goals, it doesn't matter which engine is "better" persay. Since they both rock :ylsuper
also, as was said many times, there are more NISMO parts for the SOHC because of what Nissan was using in their GT series racing, and that was the SOHC. However, if you put those HiComp SOHC pistons into a DOHC engine, you get soem crazy compression, yeah, I know, I'm biased towards the DOHC
--Justin
