KA24DET UPGRADE!!!! HELP!!!!
truth211
Car: 1992 240sx
I am trying desperately to find help on turbocharging my KA24DE engine. I have tried the search engine but find stabs of info here and there. I am so lost. However I have all the components for the upgrade. I really only needed to know what little things to look out for, from someone who has done this before. I know there are little tricks you can do and those are really what I am looking for. I have a FMIC and all piping with a new T25 turbo. I am using 370cc injectors from a sr20 and a redline ECU. I am not going wild but I plan on pushing about 225HP to 250HP. I have a BOV too. I am not sure what else I will need or what problems I might run into. Just looking for some extra info to help out. I also forgot to mention I am using a stock fuel pump, I have oil lines and a stock MAF sensor. Any ideas on running coolant lines to it? Any tips or tricks to help out would be great. Thanks.
smocan
First you should check out .org... you will find everything you need to know there, and they are probably a tad (ALOT) more knowledgable than many on here.
turbo2nr
Car: 97 240sx (kouki)
why go to ka-t.org when we have a wealth of information in out ka-t setion.. go there read the stickies you will have more then enogh information there.
as for your question its pretty straight foward:remove your stock stuffbolt on the turbo stuffdrop the oil pan and tap it for oil returntake feed form oil filterchange injectors and pumpre tune for larger injectors and your done...
250whp on a t25.. good luck..
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Please read this:zerothread/226410
Alot of good info
