KA24DET-T Gerrett T2/T4E Turbo Setup Complete List
supra33202
Car: S13 hatchback, stock internal engineGoal: 250-300WHP, quick response, drift carBoost: 8-10 psi boost for reliabilityBudget: $5000-6000 (lower is better but don't want to cheap out too many parts)
I want a good reliable typical setup. Not super expensive nor super cheap.
JGS KA24DE Turbo Kit Starter Package with wastegate without turbo (4-bolt down pipe)http://www.jgstools.com/turbo/...69878
Garrett T3/T4E, 50Trim Compressor, StageIII Turbine (T3 4 bolt .48 A/R)http://www.aptuning.net/T3_T4E...0.htm
NISSAN MAXIMA MAF AIR FLOW SENSOR N60 SR20DET KA24DE NRhttp://www.ebay.com
FMIC INTERCOOLER PIPING KIT BOV 240SX S13 SR20DET 89-94http://www.ebay.com
Westco 12V31M Miata Batteryhttp://www.batteryweb.com/miata.cfm
HKS SSQV BOV SQVhttp://www.ebay.com
HKS SSQV Recirculation Fittinghttp://www.mynismo.com/products/?ID=4793
JDM S15 SILVIA 480CC INJECTORS SR20DET S13 S14 180SXhttp://www.ebay.com
INJECTOR SEALS SET S13 240SX SR20DET GENUINE NISSAN OEMhttp://www.ebay.com
NGK Iridium IX Spark Plugs Nissan 240SX KA24DE Turbocharged Colderhttp://www.frsport.com/NGK-Iri....html
AEM GAUGE TYPE 6-IN-1 WIDEBAND UEGO CONTROLLER 30-4100http://www.ebay.com
AEM Tru-Boost Electronic GAUGE Type CONTROLLER 30-4350http://www.ebay.com
ATI EZ POD DASH GAUGE HOLDER NISSAN 240SX S13 89-94 52Mhttp://www.ebay.com
JGS Vacuum Blockshttp://jgsturbo.com/kamain.html#anchor415357
EXEDY RACING STAGE 2 CLUTCH KIT 91-98 240SX KA24DEhttp://www.ebay.com
KA24DE Lightweight flywheel 12lbshttp://www.sikky.com/view_item.php?id=133&catid=16
--------------------------------------------------Engine management:
Nistune Type 3 Package http://www.autovaughnperforman...id=73
ISIS Dual N1 Exhaust - Nissan 240sx 89-98http://enjukuracing.com/produc...{3}41
NISSAN OEM KA24DE ENGINE OIL PAN 240SX 1991-98 S13 S14 (for welding the bung for turbo oil return)http://www.ebay.com
White 7 Color Water Temperature GaugeWhite 7 Color Oil Pressure GaugeWhite 7 Color Oil Temperature GaugeUniversal Triple Gauge Single Din Radio Face Podhttp://www.glowshiftdirect.com
Water temp Adapter:NISsport Water Temperature Adapter for 240SXhttp://www.nissport.com/catalo...tions
Reference:http://pivotjp.com/product/ins....html
Oil Feed/returnNISsport Oil Pressure Adapter for 240SX 1/8 BSPT (male & female) & 3 1/8 NPT (One 1/8NPT for oil feed (not used); One 1/8NPT for oil pressure sender unit; One 1/8NPT for oil temp sender unit)http://www.nissport.com/catalo...tions
KA24E & KA24DE T3/T04 Oil Line Kithttp://www.jgstools.com/turbo/...98149
0.063" Oil Pressure Orificehttp://www.jgstools.com/turbo/...98149
Aluminum - Oil Drain Flange (T3/T4)http://www.aptuning.net/Alumin...9.htm
NISSAN EGR BLOCK OFF PLATE TURBO 240 SX KA24http://www.ebay.com
fuel pressure gauge inside the engine bay:5/16" Fuel Pressure Gauge Port Nitrous Adapter Fittinghttp://www.ebay.com
Summit SUM-800199 - Summit® Chrome Plated Fuel Pressure Gaugeshttp://www.summitracing.com/pa...w=sku
Reference:zer...age=1
PCV system (Valve cover: vent to atmosphere; PCV: install the Buick PCV valve and catch can in between the stock PCV setup):
Tenzo-R Air Breathers - Crankcase (Black)http://www.andysautosport.com/...nzo_r/
Buick GNX PCV Valvehttp://www.autozone.com
Circuit Sports (CS) Mini Style Oil Catch Tank (250cc)http://www.frsport.com/Circuit....html
Reference:zerothread?id=446254
What are your opinions and suggestions? What other small parts do I miss?
Thanks!
