I have my S13 Hatchback for about a year and I want to turbo my car now. I did suspension and brake already. My S13 is mainly for drifting, but I will drive it in the weekends too. So I want to keep my car as sleeperish/stockish as possible. Since this is my first turbo car and first time to do this, please let me know if you have any suggestions/tips.
My goal for this S13: I want to have around 250WHP with responsive acceleration. I am interested in good response and low-end torque for drifting. I also want it to be a sleeper, there is why I want to have a stock-looking dual exhaust. I also want to keep the cost as low as possible. I just want a typical good setup.
Reliability > Performance > Cost
Here is my setup:
JGS KA24DE Turbo Kit Starter Package with wastegate (4-bolt down pipe)$1028http://
www.jgstools.com/turbo/...69878
Garrett GT2860RS-739548-1/GT28RS Disco Potato BB Turbo w/ T3 4 Bolt Ex (I want a responsive turbo with external wastegate. Any advantage to use T3 4 bolts vs T3 5 bolts?)$1078.52Garrett GT2860RS-739548-1/GT28RS Disco Potato BB Turbo w/ T3 4 Bolt Ex
Deatschwerks 550cc Injector KA24DE$339Deatschwerks
Walbro Fuel Pump for Nissan 240sx S13$109.32Walbro Fuel Pump for Nissan 240sx S13
CXRacing FMIC INTERCOOLER KIT 89-94 240SX S13 SR20det (Any other good alternative?)$207CXRacing FMIC INTERCOOLER KIT 89-94 240SX S13 SR20det:eBay Motors (item 330336025834 end time Jun-12-09 13:37:39 PDT)
HKS SSQV BLOW OFF VALVE KIT: UNIVERSAL (BLACK)$244.25HKS SSQV BLOW OFF VALVE KIT: UNIVERSAL (BLACK)
Z32 Mass Airflow Sensor (Do I need the Z32 plug? What is it for? I know I can find the used Z32 MAF cheaper in craisglist.)$223.59Nissan 2268030P00 300ZX Z32 Mass Airflow Sensor MAF MAFS - USED
Apexi Racing Suction for S13 SR20DET w/Z32 MAF (Will it fit perfectly?)$301.63Apexi Racing Suction for S13 SR20DET w/Z32 MAF
Spec Stage 3 for Nissan 240sx 89-98 KA24 (Any other suggestions?)$343.67Spec Stage 2 for Nissan 240sx 89-98 KA24
ISIS Dual N1 Exhaust - Nissan 240sx 89-98 (Any other cheap stock-looking exhaust?)$357.59http://enjukuracing.com/produc...{3}41
Stainless Test Pipe - 240SX S13/S14 SR20DET 89-98 with wideband bung$73.26Megan Racing Stainless Test Pipe - Nissan 240SX S13/S14 SR20DET 89-98
Summit® Battery Relocation Kits (I know there are some cheaper way to do this.)$89.9Summit SUM-G1200A - Summit® Battery Relocation Kits – SummitRacing.com
ISIS Aluminum Radiator - Nissan 240sx 89-98 w/KA24$228.59*ISIS Aluminum Radiator - Nissan 240sx 89-98 w/KA24 - Enjuku Racing
(2) ISIS 12 Inch Radiator Fans$87.79*ISIS 12 Inch Radiator Fan - Enjuku Racing Parts, LLC
Gold Heat Reflective Racing Film (Do I have a cheaper alternative?)$37.27Gold Heat Reflective Racing Film
NISSAN OEM KA24DE ENGINE OIL PAN 240SX 1991-98 S13 S14 (for welding the bung for turbo oil return) (Does anyone sell a oil pan with pre-weld bung already?)$127.9NISSAN OEM KA24DE ENGINE OIL PAN 240SX 1991-98 S13 S14:eBay Motors (item 300259703825 end time Jun-14-09 21:58:37 PDT)
Innovate wideband O2 “Standalone Gauge Kit”$329Innovate Motor Sports On-Line Store
Nistune Type 3 Package (Nistune or Emange Ultimate? I want to road tune myself, so no Enthalpy ECU.)$500Nistune Type 3 Package
White 7 Color 30 PSI Boost / Vacuum Gauge$39.99White 7 Color 30 PSI Boost / Vacuum Gauge
White 7 Color Oil Pressure Gauge$54.99White 7 Color 105 PSI Oil Pressure Gauge
White 7 Color Oil Temperature Gauge$49.99White 7 Color Oil Temperature Gauge
Universal Triple Gauge Single Din Radio Face Pod$12.99Universal Triple Gauge Single Din Radio Face Pod
Greddy Profec B Spec-II Electronic Boost Controller$386.18Greddy Profec B Spec-II Electronic Boost Controller
Total: $6250.42
My original budget is about $5000 to $6000. So I guess I need to either save money or find alternative solutions.
I will ask a welder to weld the hot pipe, and drill/weld the bung for turbo oil return on the oil pan. What other things that I might need from a shop?
And I will road tune this car with Nistune myself, and I still need to read a lot of thing. I know I will need help on this.
1) Do I have to remove EGR stuffs for turboing my car?2) I want to keep power steering and AC. Do you think I will have fitment issue?3) Have anybody try Cxracing KA24DE intercooler kit? Do you think it worth the price?cxracing.com: Front Mount Turbo Intercooler Aluminum Piping Kit for 91 - 94 Nissan 240SX with KA24DE DOHC Engine4) I am new to turboing, so I might miss some little parts. Do you see any miscellaneous parts that I will need?5) Any inexpensive place to order those parts or inexpensive way to accomplish my goal?6) Any other suggestions/tips?
Thanks!
