Asad: Thanks for the info on the supercharged engine code. I like the sound and look of a KA24DE-R a lot more!
There are ways of adjusting the boost on a positive-displacement design. Check out
http://www.theoldone.com and
http://www.flyinmiata.com/projects/ubercharger.asp for examples.
However, I don't think that will be included for the quoted price. I have weighed the options for boost control and feel that it if you don't have adjustability, you probably won't miss it. If you do have it, you are more likely to blow the motor due to insufficient ECU calibration and/or engine management, which looks bad on everyone's resume. Besides, it's adjustable with your foot hehe..
iwantanr34: Thanks for sharing your experience. I understand this is not an easy task but I have all the technology and connections required to make just about anything (at a cost obviously).
About the misrepresentation on the KB site, I have to agree with you. The page I was hoping you'd find is this:
http://www.kennebell.net/techi...g.pdfYou might also want to check out the Lightning dyno runs. Pretty impressive.
I too looked around eBay and remanufacturers of Roots blowers but I don't feel that it is appropriate to resell a used product that I cannot personally guarantee. I also think that for efficiency and space' sake for the drive pulley (smaller), you should run a m62 instead of the m90 for less than 15psi. Bottom line is, from my research, why not start with the best technology available? Cost is a big factor but I'm not out to screw anyone (pardon the pun). I love the 240sx and feel that I can make a contribution to the KA faithful by offering these kits at reasonable rates.
Hurrikane: Wow that's great! Can you share more about your setup? I'm very interested. What compression ratio? What psi? Did you run an intercooler? etc...
About the intercooler: It can and will be available in the intake manifold for the higher PSI ranges. The stages and accompanying intercooler are going to be based on the KB Miata unit. Sorry I didn't intitially make that clear. ie. 9psi+ with intercooler.
If you're curious you can check out
http://www.laminova.com for more info. These are the same parent company that make the Autorotor, which has acquired it's main competition,Lysholm, within the last couple weeks.
Thanks for you thoughts, keep 'em comin.
-Nate
