tloof »
https://forums.nicoclub.com/tloof-u11109.html
Sat Nov 01, 2003 7:04 pm
No modifications are really required on the engine if you keep it below 8 psig boost. I would however, have the single cam KA24E head ported and the exhaust valve size increased (the exhaust side needs the most help) to help improve its flow capability to closer match that of the twin cam KA24DE head. Previous flow bench tests that were done on the KA24 series heads and posted on the FreshAlloy 240SX site indicated that the stock twin cam KA24DE head flows 240 cfm on the intake & 196 cfm on the exhaust. The stock single cam KA24E head flows 208 cfm on the intake and 147 cfm on the exhaust. As you can see the intake side of the SOHC head isn't too bad in comparison to the DOHC head (the M62 Eaton supercharger could easily make up for that difference anyway without port work on the intake side), and with some minor porting work would probably come close to matching the stock DOHC head's flow. The exhaust side is an altogether different issue, and will require massive porting work and an exhaust valve size increase (46 mm maybe?) to help bring it up close to what the stock DOHC head flows if possible. Regardless, a good set of free flow large diameter headers will be required to help get out the increased flow that the supercharger can cram into the cylinder heads!
Just for comparison sakes, if the DOHC head were to be ported, it will achieve around 274 cfm on the intake side and 233 cfm on the exhaust side (these values were also posted on the FreshAlloy 240SX site). As you can see the exhaust work increased the flow around 37 cfm, so about the same could be expected with only port work on the SOHC (this would up the SOHC head's flow to around 184 cfm which is still shy of the stock DOHC head's 196 cfm), so upping the exhaust valve size will be required to increase the flow even more! No modified SOHC head flows have yet been posted on any website I have looked at so far, so I don't know for sure what it is really capable of. One thing is for certain, the DOHC head IS superior to the SOHC head, but unfortunately there appears to be no easy way to mount an Eaton blower to the DOHC engine like there is to the SOHC engine. This is why I am going to stick with my existing single cam KA24E engine that I swapped into my '85 Nissan 720 pickup, and just add the MP62 Eaton supercharger to it (that is with a modified head to approach the stock DOHC head flow capability).
The only other modifications to do to the engine is to add stock Nissan 300ZX TT 370cc injectors, and have the ECU reprogrammed by JWT for this setup.
By the way, I'm not planning to offer a supercharger kit for any of the KA24 series engines, I am only doing this conversion on my own KA24E engine. I only brought all of this up for helping others on this forum to plan their own conversion, and for any comments others might have to my ideas.
