When I look at buying a 240/motor, I dont mess with it if it has less than 170+/- across the board on a compression test. I believe nissan specs say 180psi is optimal, 150psi is minimal(someone correct me I know those numbers aren't exact).Firewind wrote:Are they really that low? I mean I have heard of KA24DE's with 140 across the board and they seem fine with doing a turbo.
About 2 weeks after is when I noticed that I had the leak.
one other thing that I have noticed I have an exhaust leak from the headers leading down to the exhaust pipe. I am noticing fluid leaking from it when the car is running, feels and smells like gas. Hence I am wondering more about the FPR.
hay spin..there is that pocket for coolent on the intake of the ka24de twards the front of the block..that might be his coolant leek!..the rpm's have me baffled thou...that would allso explain the gas oder allso.spindrift187 wrote:You DEFINITELY should not have gas leaking from there. The only thing that boggles me is that would not cause the smoke you are seeing. White smoke is coolant, so unless you somehow routed a coolant line into the intake mani(I know i know just sayin) I dont see where that's coming from. as far as the 2500rpm limit, Ive only ever known a MAF to cause that.
Good call I didn't even think of that. Ive seen people put injectors in and the O-ring on the fuel rail gets messed up and even with just the key turned to the on position(fuel pump priming) it dumps fuel. That's the only time ive ever seen fuel actually leaking out of the exhaust.liquid_cool wrote:if your thinking mass amounts of gas is your culprit..then you only have one place to look...the injectors...its easy to see if that is the issue..pull the fuel rail of and have a buddy crank it over a bit..if gas is pourin out/not comin out..then its possibly an injector issue.
thats exactly what i was thinking of...rite in that area...remember..when hot..the coolant system is under pressure..the intake is not..so if there is a week point in the ghasket there..the coolant will push throu when under pressure....hope this helps....im getting ready to do a mod on my intake..its a hybrid of some i have seen..im going to separate that coolant area from the intake by using a modifyed plate i will make patterns today and get it going..ill post on it in the same place...my myspace...hope this helps.spindrift187 wrote: OK now I remember what you're talking about liquid.
Is there ANY coolant leaking around the manifold area? The other lines im thinking of are generally just capped off so it's not like they'd get routed into it. The only thing I can think of is possibly some coolant seeping over to the intake ports due to a defective gasket(deformed/torn?) or not being tightened down enough. Other than that im pretty much stumped.
AH spoken like a true backyard mechanic. don't understand it remove it to bad the ecm and every other componet is designed to work with everything intack. But I guess you know more It may be a billion dollar parts industry praying on unsuspecting people that don't know any better. When emission control was first intotuced 30 years ago I my have agreed with you A factory made RACE car is far from trying to out do the engineers that designed your street car good luck stay under the tree when you are working on your car sun stroke sucksVegascorbin wrote:Ok, you don't know what you are talking about.
#1 Automakers RARELY make an engine perform at the top level. Their lawers won't let them. That is why they have race teams.
#2 An EGR (Exaust Gas Recurculating) valve is designed to DEGRADE engien performance, by inserting exaust gas into the intake, but IMPROVE exaust emissions. It is strictly for polution control.
#3 Why would thousands of people that are trying for top PERFORMANCE remove the emissions systems from their cars if IT WAS GOING TO MAKE THE CAR RUN WORSE????????
Do not assume that the manufactures way is the best way. There is a multi-BILLON dollar aftermarket parts industry that proves you wrong.
maVegascorbin wrote:I am so glad that you know all and are the expert in everything.
And you were so nice to let us know this in less than 30 posts.
I bow before your obious superior inteligence. If I want to know anything about everything I know to ask you o great one.
