ka24de vs. ka24det - Round II
WDRacing
Dover...you know, the F'n capital of Delaware! Jesus Adrian! All the progressiveness making you a bit ratahded?
Just retiring from the USAF, still haven't hit 40 yet. Although Kate hits 40 in June this year. Buying a nice place with some acreage up in PA so I can prep for the end of days. I hope it's zombies...
Razi
Car: Moo
adrianfromthecastle wrote:Image
:spitout:
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
So dumb mistake by me. Did not know S14 differentials used bushings on the front mounts. Now I have order. 7 years on here and no clue. Fail.
WDRacing
It's not something you're gonna know until you're doing the job.
GTR PrYdE
I have been hearing alot of dislike for energy suspension bushings. Enjuku sells a oem set for 70+ship with hardware. Thoughts?
WDRacing
Nothing wrong with OEM.
Razi
Car: Moo
Mount the diff solid like S13 diffs.
WDRacing
I'm not a fan of any solid mounts. The S14 is clearly an advanced chassis by all comparisons :poke:
Razi
Car: Moo
Well, we have cool pop-ups, so there.
WDRacing
Pop-ups...how...desirable.
SiDwAyZ240
Car: 95' SR Slayer, '02 LT Tahoe, '03 Chev Express is the DD
pop-ups = so 80's
GTR PrYdE
Razi wrote:Mount the diff solid like S13 diffs.
I thought about that! But read there was a decent amount of noise with poly mounts. I'm now second guessing whether I should install my ES master bushing set.
WDRacing
The noise occurs when the bushings aren't properly lubed.
Razi
Car: Moo
Pop-ups are the raddest.
I doubt you'll get much noise from the diff bushings as long as there is adequate lube. ;)
WDRacing
Proper lube is a lesson for many things in life.
GTR PrYdE
The problem is the lube runs dry, and we all know that leads to.... friction... ouch. I don't want to remove the bushings to relube every time they get squeaky.
I'll hold off on the ES kit. Not sure what i'll go with, probably some rubber replacement bushings in the future. What I have now isn't terrible at 150k miles, I just thought i'd change them to the ES bushings...
Also- i'm very excited to run my Cibie lights, so +1 for pop-ups.
SiDwAyZ240
I just don't like how the pop-ups take away from the aerodynamics. I don't know if it can be done on a 240 but I like when some people remove pop-ups and install the recessed GT class style lights. A lot of people do it on the Rx7s
Greasing poly bushings sucks, the grease is real thick and gets on everything. Don't drop a bushing after you have greased it either or else you'll be forced to install a poly hair ball....
GTR PrYdE
Ok so I wired up my new 12ga wiring harness, oh...my...goodness. Like 4 hours of soldering, heat shrinking, making sure the correct wires were routed...installing then... They work though! Need to get them adjusted, just have to drive somewhere flat with a wall. My driveway is at a major incline
Cibie H4 w/ Narva 90w/100w bulbs. Should be awesome.
Chris28
Car: 92 s13 KA-T
Woah, long time no post. What's up dudes? Razi turn the boost up already!!!
WDRacing
He's scared...
How you doin Chris?
Chris28
Car: 92 s13 KA-T
I'm doing great, almost done with school, not looking forward to the real world though haha.
Car is doing well. Just got it tuned, made 366whp and 355 ft/lb at 16 psi :biggrin:
WDRacing
Not bad buddy! We need to have beers this summer before I move up to PA. Maybe I'll come down to VA.
Chris28
Car: 92 s13 KA-T
I plan on going to some events at Summit Point in WV, if it's close enough you should come out!
SiDwAyZ240
Chris, why not bring the car up to Carlisle? WD your going right?
WDRacing
Yup.
SiDwAyZ240
I'm excited to meet some of the people that have helped me get my car going. I just hope I can get it track worthy in time......
Chris28
Car: 92 s13 KA-T
How is the track at Carlisle? I might head up there, it'd be a fun road trip. Any excuse to burn up some tires is a good one!
WDRacing
It's a pretty short course, but definitely fun.
GTR PrYdE
Ok so I have a denso o2 sensor and a fitting I overlooked for my fpr(so I can install my fuelab fpr) being shipped. Which do you think will solve my rich cruise issue?
Symptoms- random richness while cruising, between 11-12:1 at times it will try and "hunt" between 13:1 - 16:1, but mostly just rich cruise. Idle will mostly idle 14.2:1 but goes rich on.occasion too. I have never had a wide and on the car, except when it was tuned, so this may be a long occurring issue. Haven't done any full wot pulls but when boost hits it stays a solid 11-11.5:1.
Thoughts?
WDRacing
New O2 should help and it's always good having a solid fuel pressure.
