Frank E Bones wrote:Razi wrote:It's a bit soapy so it'll probably make it all dirty right?
Soap gets things dirty!? Damnit, ive been doin it wrong this whole time
How often do you plan on spraying the radiator/intercooler? At certain temps or something?
Plus the canister you plan on using has to have a decent capacity for it to be effective, doesnt it?
I thought that soapy water might leave some residue on the radiator.
But I'm not really sure what the washer fluid is.
Chris28 wrote:Ohh I like where you're going with this Razi haha.
Pure water shouldn't hurt it, you should be good to go.
Fo sho!
I got a rear washer pump + rear wiper button from a hatchback.
Except this washer pump will spray my radiator and intercooler, not my rear window. :P
Right now I'm just wondering if I should install this pump on the washer tank and just run water in there, or leave the washer fluid and the tank alone and make a separate tank for this spray setup.
