homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Wed Jan 19, 2011 3:59 pm
Razi, look around on Summit. I'm sure you can find what you need at a good price. If you're not going to run a thermostatically controlled unit, you need to buy a small cooler. Really, you should get a thermostat, a good oil temp gauge too, run the small cooler, see what you're running temps are and adjust cooler size from there. But, if you're not going to get the thermo, at least get the gauge so you can assure you're not running your oil too cold. Cold oil doesn't lubricate as well and will kill your bearings. Briz, I mis-read your earlier post and thought you said you were going to try for 350whp. I see now that you typed, the turbo was good for the KA UNLESS you wanted 350whp.
