2 maybe i messed up in reassembling the timing chain on the cams.
i have found some help from another thread on how they should be positioned since the ****ING chiltons is a waste of my money. i can't find the needed info there. thanks to drjohn i do have some helpful info.
drjohn wrote:Int.cam lobe tends to point to the valve cover gasket surface at about 45 min as on a clock and the ex. cam is about 15min after and pointing to the valve cover surface. The links between int. and ex. cam is 14 links.14 links ex cam and lower idler gear and 24 links from idler to int. cam. The chain should still have shinie or faded yellow links on it at timing points. Make sure eng. is tdc on compression stroke before setting valve timing. On that model if you have it down that far remove and discard both top chain tensioners as they are not needed as per the factory. You should consider doing a complete chain and gear replacement if the timing has jumped do to loose chains.
so for me to figure out if my problem is 1,2 or both can someone inform me of how i can tell if my engine is at 180 cam of TDC.
on another note where can i get a FSM? a NISSAN dealer?
