KA24DE-T
RTKA24
i have a ka24de i am planing to run 5psi or what is the safest amount i can run on a stock engine?? and also would i need to change my fuel injectors to the sr20 ones running only 5psi im new at this i dont know much
Chris28
Car: 92 s13 KA-T
Alright I directed you here from the KA section, but that doesn't mean you just make a new thread. You have to do some research for yourself, especially if you plan on boosting an engine that did not come factory turbocharged. If you are serious about adding a turbo to your KA without blowing it up, then you should seriously learn how to find things out on your own. You can't have information spoon fed to you your whole life.
zerothread/226410
ka-t 300
Chris28 wrote:Alright I directed you here from the KA section, but that doesn't mean you just make a new thread. You have to do some research for yourself, especially if you plan on boosting an engine that did not come factory turbocharged. If you are serious about adding a turbo to your KA without blowing it up, then you should seriously learn how to find things out on your own. You can't have information spoon fed to you your whole life.
zerothread/226410
+1 here, you need to under stand how every thing works because you dont just it to the shop and they will fix it. you are pretty much going to have to fix it when some thing is not working right. so do some research so you under stand how the whole thing works. good luck to you when you do it though.
supra33202
zerothread?id=446516
I also want to turbo my KA24DE, and I did tons of research already. See my thread for references.
