Yea, thats pretty much exactly the point. Seriously, WD has been around since i was fkin with a Ka24de and the stock trigger wheel. At that point, no one that i could find on the WHOLE INTERWEBZ had done a ka24de before. It was all DIY-Autotune 'theory' i believe. I was down for 3 months during my learning period with the ECU. Although i got it started, running and drivable, i never figured out the CAS thing till later and killed a starter. Lol till someone else figured it out, i got fed up when i left my ignition on overnight It killed the battery, in addition to that it got the ignition driver 'chip' so hot that it desoldered itself from the upside down board mounted in my car. I ordered 2 of the new chips and was like wait, i want to drive my fvking car. Then i got a rom tune and jacked the SAFC off my SR. : )WDRacing wrote:Show me a large group of KAT guys that have the MS running trouble free. Trouble free meaning no idle/stalling issues and no issues with start or rich conditions. By large I mean 100 or more...because that's what it takes to be considered reliable and functional.
Yea I was actually thinking about that earlier,I'm sure it's a bit thin especially with how rich it was when I first got it to start... I burned thru a 1/4 tank of gas in about 30-45 mins of idling lol. It took me forever to get my base timing set, ve's tuned down, spark tables semi set. etc,etc.WDRacing wrote:Change your oil after you get the idle tune done. Lots of rich blow-bye gases will destroy your oil quick. During the tuning process I change my oil often...which is why I use chepo oil until after the tune is atleast decent.
Just a tip...
No hard feelings at all broflynbyu82 wrote:Ar
WDRacing, no hard feelings. Not judging you; it just seems to often people jump to conclusions and blame their own short-comings on MS.
I haven't yet fooled with the Mitsu wheel, I found the compatibility listings while searching on this site. Apparently the 90-91 with the "green top" and optical dizzy are the correct ones. I will try to find a link and post it back.flynbyu82 wrote:Ar
Have you fooled around with the DSM dizzy? Do you know what year and model vehicles have the dizzys that are interchangeable with the KA?
Also, do you only need the single IAC? The FSM discusses three and I'm curious how you guys are adressing that...
What did the EDIS come off of?SR24DET wrote:So I went to the junk yard and pulled a Ford EDIS system for $40. I am in the middle of my build (see CJ's build) and was planning on running MSII. I have read tons of threads and nothing has made me more worried then this one. I am starting to rethink my plans. I wanted a EMS that I could tune myself so when I make changes I dont have to send it out. I want to lean how to tune. I am a very mechanically savvy person, but have never done anything remotely related to tuneing. I wanted to run MSII for 2 reasons. 1 I mentioned b4, wanting to tune myself. The second is I wanted to simplify the wireing. I am rewireing my entire car. I am going to make a new fuse/relay box under my dashboard. I am elimenating all extra wiring. I thought MSII was a cheap, good way to go, but.... you guys are makeing me rethink things...
The FORD EDIS-4 parts can be found on 1991-1995 FORD Escorts.Invallid wrote: What did the EDIS come off of?
Just tell me what you want and I should be able to accommodate. I have taken a few pictures as the project matures... maybe there is an article you can site with a format that you want to have us follow. Unfortunately with the MSII there aren't a lot of "look how cool this looks" pictures its just some solder and butt connectors lol.WDRacing wrote:Guys that enjoy this type of thing are definitly an asset to NICO. Would you mind doing a write-up with pics? I can get it on the NICO homepage and also in the Tech Section.
While doing alot of my MSII reading. I have read this a number of times.
http://www.nicoclub.com/articles.php?id=179898
It didnt seem to bad to me. Im not worried that I can't wire it up, I'm more worried that I wont make it run right. I have never dabbeled in tuneing and this will be a first. I love doing things myself. I also enjoy a challenge. I refuse to bring my car anywhere to have work done. While read about MSII, it didnt seem too bad. It seemed like Iwould wire it up. Then download the stock fuel maps and ignition chats. At this point I assumed it would idle fine and drive without boost fine. Then I would have to tune it to run with my turbo. As I read I am finding out that I would have to d!ck with it to get it just to run (without boost) fine. While I am not totally afraid, it has made me more nervus. I plan to rewire the entire car (engine... lights... everything). This is my race car so I am going to run the bare minimum. No extras. No radio. No AC or heat. I removed all the sensors off my intake mani. I blocked all the vacume ports. I blocked the EGR and the IVAC or whatever that sensor is back there. This will be hard at first, but once its all squared away, it will be easier to trouble shoot down the road. MSII interested me, because It seemed like I could run a few wires, and learn how to tune after that. Hummm..... lots to think about.
Interesting. I still have my engine out and I have alot to do b4 The MSII is gona be wired up. The engine is just about done, except I need to connect the timeing trigger to the crank pulley and I also need to make a bracket for the sensor to read the trigger. I need to put the shell back together and I am still doing a couple other things on the side. I will be checking this frequently to see how things go for you.Invallid wrote:
I think your thoughts are exactly in line with mine. If you want to wait a few more weeks I will be the guinea pig. I am already to far into this project to back out now. I have all of the components I need to get the car running in "stock" form and everything but an exhaust to do the turbo side of things, I am currently pulling thru intercooler piping ->intercooler ->piping ->air filter so I can drive the car before I boost it and make sure my idle settings and other basic preboost tunes are happy. I figure there is less risk of blowing it up with a turbo if I get it road tuned without. Once I am satisfied with how the car works I will bolt on the turbo,manifold, plug in the EGT make the connection from turbo elbow to the hotside pipe , put the WB 02 in its new home throw on a downpipe and fire it up, over all about a 1/2 a day process if that.
Good luck in whatever you do.
Yep, everything is in place for the turbo except the turbo stuff essentially lol. Big injectors intercooler, piping, bov etc. I think because you are doing a crank trigger you should have no issues, as has been reported in this thread and others it is over all the CAS that causes issues. Take that out of the equation and you just have a motor... any motor 12 cylinders and under can run on a MS once it has proper trigger for spark/timing.SR24DET wrote:
So your not gona mount the turbo right away? Your gona keep things stock and tune it that way first. Then put the turbo on later. Neat, makes sence. Good luck. Make updates
Good information, unfortunatly I don't know that I would be the ideal canidate to do the write up being as how my wiring is about ~90% done... I don't want to pull everything back apart to do a proper write up.. besides a lot of my stuff has been trial and error with the idea of "oh this will work" and then in the end I end up doing it a different way because I find that something else works better...WDRacing wrote:
Here's an article I wrote on alcohol injection. Anything like that...We also have guys to assist with the writing if you need it. So long as you don't mind others editing your write-up. Pics of running certain wires, what sensors are what, where did you get the MSII setup etc. All the way through to tuning. We can even make it more then one part and do a series of write-ups.
Project MegaSquirt has a nice ring to it. I'm more then willing to help with whatever. Hosting pics, writing, editing etc. Just let me know what you need and I can get the resources to assist.
A really complete start to finish MSII article would be awsome dude. Home Page material for sure. If you're interested I'll drop a line to Greg (AZHitman) and see if he has any suggestions.
WD
LOL, what would I do with out the support of people like you.WDRacing wrote:I see a new wiring harness and a FMU in your future
