TonkaTruckin »
https://forums.nicoclub.com/tonkatruckin-u120956.html
Thu Dec 18, 2008 8:29 pm
Alright.. so there i was. Bored at work and siting next to a computer and it donned on me.... why don't I just check the Technical Service Bulletins! what a dummy. I feel dumb for not thinking of this first. But that is what you get for working on cars all day.. common since sometimes goes out the window.
So here it is.. word for word. So it is not my problem if it doesn't help anyone.
Date: April 17, 1996ENGINE CRANKS, BUT WILL NOT START OR IS HARD TO STARTService Information: This bulletin has been developed to address complaints of an engine which cranks over normally, but is difficult to start or will not start at all.
Service Procedure: *Connect CONSULT. If the vehicle you are working with is not CONSULT compatible, connect a tachometer (digital readout if possible).*Start the engine (the accelerator may have to be opened and/or the the fuel pump fuse removed during cranking to get the engine to start), and warm it to operating temperature.*Run the engine at 2000 rpm (no load) for two minutes. Then shut the engine off.*Check the oil level and correct as necessary (between the "L" and "H" marks on the dipstick). If the oil level is overfull and has a gasoline odor, change the oil and filter before performing this procedure. If the crankcase is over full with oil, idle speed adjustment may be affected.*Disconnect the throttle position sensor (TPS) connector. Now re-start the engine.*Rev the engine 2-3 times to 2000-3000 rpm, then allow it to idle (all accessories "off").*Check the ignition timing with a timing light and adjust it to specification (if necessary).*If the vehicle is not CONSULT compatible, monitor the idle speed using the tachometer connected in step 1. If using CONSULT, perform the following procedure: Monitor the idle speed (CMPS.RPM) on the CONSULT screen.*Check the idle rpm and adjust to specification (if necessary) using the screw on the IACV-AAC valve.*Turn engine off, and re-connect the TPS.
So there you go.. I myself have not done it yet but i look forward to giving it a shot when i get the chance..
