Do a search and check the KA-T forum, this has been covered pretty well.
Mr240dude wrote:My KA has app 146k and is healthy. I hear people turboing them with a bit more miles after getting compression tests done with good pressure.
You want good compression on every cylinder and you want them to be within 5-10 psi of each other. Your engine should have absolutely no problems. Turboing it is going to compound any issues that it has
Mr240dude wrote:What is the process exactly turboing the KA? Costs,materials needed,time,HP gains etc. I hear good and bad about <a class="vglnk" title="Link added by VigLink" rel="nofollow" href="
http://www.ebay.com/">Ebay</a> turbos which are enticing at roughly $500 nearly complete set. I'm not made of money so one of those $2k sets isn't gonna happen.
This isn't a cheap adventure, it costs a good about. Stay away, from ebay turbos. STAY AWAY FROM EBAY TURBOS. Intercoolers and piping should be okay to get from ebay, however get a good turbo. Don't cheap out there.
- For your 250hp mark, you'll want a garrett T25(from an s13/s14 SR) or T28 (from an s15 SR). Depending on what kind of deal you can get, if you buy used or new, this can cost you anywhere from $100 bucks used, to $1200 new. If you buy a used one, chances are you'll want to rebuild it.
- You'll need a turbo manifold as well, this will set you back around $100-$300.
- For 250hp, 370cc injectors from and sr20det should suffice, but really you want 550cc injectors, which you'll have to buy new from a company that remanufactures them. Expect to pay $200-$300 here.
- You'll need a Rom tune for you ECU. Sending it out to someone to get it tuned can cost you $200-$350.
This is assuming your engine is in good shape and you don't need to fix/rebuild anything. Aside from this, there are a bunch of odds and ends that you'll need. Couplings, oil lines, coolant lines, turbo plumbing stuff, mounts, hardware, blow off valve, etc etc. It adds up. Boost isn't cheap, but its worth it to do it right. If you don't have the money right now, I suggest to make a list and write down actual prices that you see. Save up money for one thing, buy it. Save up money for the next thing, buy it. It will take a long time, but in the end you'll have a quality build that you don't have to worry about.
Or you can slap an ebay turbo kit on there with an FMU and wait until it explodes.
Good luck sir
