so please this is my first build and ive worked my a** off so try to show a little respect...
im not really sure how i missed this gaping whole on my intake this whole time. what does it connect to? i've looked around a bit, but most of the time ive been focusing on trying to figure out other things. so...yeah
what does the AAC?IAVC pipe actually connect to? in the write up on here it says it goes to your intercooler. "this is the tube coming from the iacv. to this you need to attach a hose that will go to a plug in your intercooler after your ic and before the throttle body" it looks like it just connects to your intake correct?
all good here i assume...?
what do these two plugs go to? are they necessary?
the needed brake booster vacuum line is the big fat one right?
i removed the charcoal canister and there are two vacuum lines. they were talking about angling one of the lines a certain way for ventilation. which line is it and how exactly do you do this? i never got to see any pics.
ok so im leaving a vacuum line for the fpr,the brake booster and the thing on the top of the intake manifold. the swirl control valve or air idler something or other
